96 trans am wnt start please help
Car has new battery,fuel pump,and fuel filter. Now the fuel tank gauge doesn't read and the car will turn over but wnt start. I'm taking the starter to get checked tomorrow but besides that I dnt no what to check. Any ideas?
Hook up a pressure gauge to the fuel rail's Schrader valve. You should turn the key forward to the on position but not trying to start the motor. You should read ~42psi on the gauge. If you aren't, then I would double check all of your work with the fuel pump replacement job you did.
The most likely problem is something you did to "fix" it....don't ask how I know this lol. I had the same issue for several miles of driving with the gas gauge when I did the racetronix fuel pump/hotwire kit. Now, my gas gauge only works between 1/2 tank and full If it says half tank you are out of gas! The racetronix hotwire kit has a fuse in it that apparently is pretty easy to blow causing no fuel/no start .....took a bit of troubleshooting to figure that out. Try pulling the quick connect fuel line out of the filter and see if the pump is doing anything....maybe you didn't wire something right.
