cc503!
The total from summit was $715.70 which included only rocker arms, valve springs, and valve seals. So what do you guys think? I probably won't buy the lifters as my car only has 110k on it.
A cc503 does not need those patriot springs, I assume your looking at the 8401's. I run 8401's on my 226/232 .606/.603 108lsa, a cc503 is quite a bit smaller and more tame! Basically they are kind of overkill for a cc503. I would run Alexs springs heres a link, but you will need new valve seals to go with it, which are 15-20$.
http://www.alexsparts.com/lt1-valve-...rs-locks-cups/
Now that youve saved 175$ on springs you dont need anyways, you can get new LS7/GM oem lifters. they are about 125-150$.
Hopefully thats some good advice.
I say don't fix something if it's not broke.
As far as pushrods, you can get trickflow chromemolys for pretty cheap.
Another thing I learned is that you dont need to waste time or money on a shim kit if your heads are stock.
Posted from LS1Tech.com App for Android
I am commenting I am looking to do the similar as OP, but will replace everything. LE1 as mentioned before would be good, but it doesnt not include the RR and springs correct? What is the OPs budget?
Heres the link to the Lloyd Elliot LE1 setup.
They do come with upgraded springs but no RRs. For 1400 bucks you send him your heads and he ports them, ports your intake fully, and you have a choice between 2 cams the bigger cam will have a lot higher chance of spinning the bottom end. Hes a cool guy if you choose to use this setup he will talk to you personally and tell you what your power ranges and pros/cons wil be.
) 52mm TB..the car ran 13.8 up here in Vegas with 3000' DA He then added the 503 cam and springs went back to the track and ran 12.77 3600'DA and the drivers side header was hitting the floor on the shifts causing the knock sensor to retard the timing..... GREAT CAM I feel put it in and be happy.
