ls1 cluster in a lt1 car need help asap
my car now has a ls1 pcm in place of the ltx pcm and cluster. Can I just bolt the cluster in the dash and have 0 issues or will have some?
What is there to expect with issues if any?
thanks
thanks
I did a ls1 dash swap in my car recently however, I used the original LT body harness due to running the LT engine and pcm still. Only thing I did was re-pinned the cluster plug with a ls style. Not sure if this helps you though. If so I do have the diagram to re-pin and shows the connections for lt and ls. Good luck and let me know if I can help....
If you can send em over to me please
thanks
Im sure if you can get the right diagrams it will be simple, i just re pinned a harness and like i said i have all guages working for me, just need to swap the wires in the port to read the computer.
