Test optispark wiring came up with an unusual reading?
Hey guys as some of you might know I have been having a problem for a while here with my randomly shutting off. Well I through another optispark at it and well the problem got worse, it will not start at all now it only backfires out of the exhaust. Well l when testing the opti I got a rather interesting reading. The read are supposed to be
Optispark Harness
A = ~5vdc
B = ~5vdc
C = ~12vdc (or your system voltage)
D = ~0 - 0.2 ohms ground
Well for position D I got .865 ohms, what does this mean? And what should I be looking for?
edited 11/9/2011
Optispark Harness
A = ~5vdc
B = ~5vdc
edited 11/9/2011
.865 ohms is not much and very close to the accepted reading. I would not consider it an issue. Some slight skew can be from your meter leads or where you selected your ground spot.
Thanks for the help though, I'm going to take the opti off and verify that it is on correctly then I'm going to try get in contact with bob about testing my LTCC box, that is pretty much the only thing left.
