First time digging into this car, opti replacement & more.
anyway current problem is the removal of the balancer, everything i read says you didn't need a puller but she's not coming off now with the bolts removed.
when it's off and you want less fuss out of it next time clean up the mating surfaces.
Didn't realize how small the "keys" are on the opti to line up when re installing, i never did see it I just assume it's there will worry about it tomorrow. This is going to suck installing all from the top.
I know get thread sealant for the opti screws. What about the water pump bolts? or anti seize? I need to look up the torque specs for everything, last year i snapped the bolt on my tstat housing
lol White thread sealant for every water pump bolt. Blue loctite for the opti bolts.
MAKE SURE you line up the correct key with the dowel pin...there is only ONE. Otherwise your spark timing will be off.
Ani seize is only needed for the spark plugs...
Here is every torque spec you should need... http://shbox.com/ci/fastener_matrix.html
Also. Leaving the air pump off and took off the tubing that leads into the manifolds. Just plug them up and i'm set?
On the back of the opti will be 3 indentions for the bolts, and 3 slots. 2 slots are the same, one is different. You need to use the one that is different from the other 2.
94 lt1 right?
The keyed spline on the opti is pretty obvious if you take a look at it. It is kind of a pain to line it up with where it slides into the timing chain sprocket since the keyed part is soo small. So dont force it on too hard.
alright here's round two of the retarted questions go easy.
I looked at my opti today and it doesn't match either of these...
http://shbox.com/1/93-94_opti.jpg
http://shbox.com/1/opti_back.jpg
Instead it's this...
and the car looks like this
the f am i suppose to replace it with?
edit... before you get everything all the way back together, put the balancer back on and snug the opti up and see if the car will run for about 30 secs... it won't hurt anything, and sure saves some time trouble shooting if you mis-keyed the opti or mixed up a wire.
