crank hub
Also MY LT1's dampener / balancer has 'balance' holes drilled in the back of the unit in-between where it bolts to the hub where the serpintine belt rides; again, NOT thru holes, but rather holes which seem to indicate the removal of material simply for balancing the rotating assy.
Also, when I disassembled each motor, both crankshafts did indeed have keyways cut into them, but neither had keys installed, nor did either of the hubs have provisions for keys. The press / interference fit, and the torque on the center bolt (74 ft lbs) was all that was keeping the hub in proper orientation.
Also MY LT1's dampener / balancer has 'balance' holes drilled in the back of the unit in-between where it bolts to the hub where the serpintine belt rides; again, NOT thru holes, but rather holes which see.
