crank hub
Ok I'm a little confused right now my crank is cut for a key but I emailed a company called trans am creations and the guy told me "The LT1 does not use a key. The crank is machined for a key because it is also used in other applications. The hubs are not machined for a key." Also the picture on shbox shows it using a key. Is this guy wrong? And yes I believe it was the original bolt with the spacer.
Page 6A3A-12
Match mark crankshaft hub to engine front cover assembly
The crankshaft hub can be installed by a different procedure if the engine should be accidental be cranked over after match marking the hub and engine front cover assembly.
A. Set number 1 piston assembly to Top Dead Center.
B. Install crankshaft bub with cast arrow on hub in the 12 o'clock position
