Diagnosing Knock Retard
Knock sensor and Knock module are both brand new.
It was not pulling any knock when we first loaded the tune but now it is. I need it to stop. I dont have any way to tug on the exhaust at the moment to make sure it isnt hitting because I can't really get under the car, so is there anything I can do to eliminate OR CONFIRM that this is detonation so I can move to the next step? This is the first time I have ever seen knock on my car so I am a little lost on how to make it stop...
The higher octane wont detonate, so if its false knock, the knock will still be there with the high octange.
The other thing i did to make sure it wasnt real knock was command 25* timing at all times. ( i have hptuners and can do this via the vcm controls on the scanner, 24x swap up in here
) Go for a rip with the timing set to only go to 25*max . Still pulling the same amount of timing in the same places, so i know that its not because of too much timing.EDIT: Roller rocker noise will set it off also. Maybe go over that to make sure nothing loosened up
Could ANY of this be related to a bad Coolant Temp Sensor? (The one in the WP, not the one for the gauge.) Just curious
Ive read on some diy tuning websites that too much timing will cause it to ping/knock.
The high octane fuel will rule out fuel being the issue causing detonation. If you run high octane fuel in it and get no change in the knock then its a pretty good indicator its false knock.
Mine is only showing up at wot , high rpm and around .7 / .8 g/cyl area. I have nothing under 3000rpm.
Cruising it would bounce around a lot...anywhere from 5* to 0.06*. I am seeing anywhere from 0 to 44* of advance......It is bouncing around A LOT. At 40 mph and 2000 rpm's kPa is right around 40-45 and I am seeing 41-42* Advance.
WOT it was between 3* and 5*, I am showing 32-36* Advance at WOT with a kPa bouncing from 79 to 84. With the engine off my kPa is at 85.2
My timing is all OVER the place and it shouldnt be should it??
Not yet, I am flat broke and don't get paid for a few more days...
