metal clinking
Old Aug 15, 2012 | 04:55 PM
bizerk1's Avatar
Default metal clinking
so today, I was driving and hear more than the normal suspension noise my car has. it sounds more of heavy metal on metal clinking from my driver side front. is that my strut, did it go bad? or is it something else in my suspension.
is there a possibility it can be my oil pump or pan?
Posted from LS1Tech.com App for Android
Old Aug 15, 2012 | 04:57 PM
Z28Camaro30Ann's Avatar
Is it RPM related or is it MPH related? Does it only happen on bumps or is it a constant "clinking" that speeds up and slows down or what?
Old Aug 15, 2012 | 07:44 PM
bizerk1's Avatar
it happens both when speeding up, even at low rpm and hitting bumps. it sounds like it is coming from front driver side wheel and its becoming worse
Old Aug 15, 2012 | 07:55 PM
So quit driving it. If it is not RPM related then it has nothing to do with the engine, oil or anything like that. If you put the car in neutral while at say 50mph and rev the engine, the sound either increases and decreases with the RPM's, or it decreases slowly with the speed of the car.
If it is speed and bump related, then you need to start checking things like your tie rod, sway bar, check to see if your shocks have collapsed or is you broke a spring...make sure all of your bolts are tight and the castle nuts are there with cotter pins in them. Make sure your bushings are ok and there, and make sure there are no broken pieces. I would keep from driving it until you figure out what it is and what it takes to make it stop. It could be very dangerous to drive it because there is no telling what it about to happen. Also check your brakes...I had a caliper bolt break once and had an issue with a lot of noise. Just take the tire off and start trying to figure it out.
Old Aug 15, 2012 | 08:09 PM
bizerk1's Avatar
I just ordered new brakes, so I will find out from that. From the sound I am thinking it could be the strut.
Old Aug 15, 2012 | 08:19 PM
warriorcustoms's Avatar
Prolly wore out Stock Rubber Bushings If you dont mind a firmer ride Get the complete Poly Suspension kit Lasts way longer than rubber & takes curves like its on rails after the install
Old Aug 15, 2012 | 08:25 PM
bizerk1's Avatar
I believe I am missing the bushing on that side.
Old Aug 15, 2012 | 08:30 PM
Get the poly kit that does the whole suspension Itll handle better Itll transfer vibrations easier If you have any Ive got my 1st set on my 2nd car LoL
Old Aug 15, 2012 | 08:37 PM
bizerk1's Avatar
I have mad viberations, from exhaust
Old Aug 15, 2012 | 08:39 PM
bizerk1's Avatar
Im looking at the kit, I have new motor and trans mounts. Do they sell a kit minus those.
Old Aug 18, 2012 | 08:34 PM
bizerk1's Avatar
what is the specific part between strut and the strut mount?
Old Aug 19, 2012 | 04:12 AM
The complete poly kit comes with everything but the trans & motor mounts. I got mine from jegs or summit like 5 years ago!!! I think the price has come down since then. The strut mount is prolly on the WS6store or other sites. Hope Im not too late LoL Been kinda busy
