Calling all Bolt On Cars!
Im driving out on street tires and bringing my big n littles, so if that really is legal to have a tire loose in the back of the car I will just do that. Otherwise the front sway bar will go on with only 1 end link plus the back seat and a full tank of gas and I should be good. Valvesprings pushrods and guideplates came in today, gonna start the install tomorrow. Also cheaped out and bought a new prebled slave and master for $93 on rockauto (flame suit on)
yeah you can't do that any added weight can't be loose in the car. but im sure you will be fine with a full tank and rear seats. best places to weigh your car are at highway weigh stations when they are closed and no one is around they are always the most accurate. i haven't done a thing to my car and made weight perfectly last year so im not worried.
Here is Kyle Kline's winning pass from last year. Watch at the 2:08 mark as he pulls into the timeslip booth. You can see the scales on the right. There is a digital readout right in front of you.
That's just like MIR where I weighed my car last week. If the seat and full tank of gas and sway bar are not enough I'll do the dumbbell idea, thanks.
How long do we have to make shakedown passes before the events start? I plan on getting to bg between 4 and 6am and taking a 2 hour nap in the car or on the parkinglot before setting up.
Tony, I hear you are a pro at icing down between passes, what kind of ice bag do you use that doesn't leak water or melt on the intake manifold? Or is that a trade secret you arnt willing to give up? You only lost 2/10 from your pb to your winning time last year in 3500 DA, so whatever you did obviously works.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I was born and raised in Fairfield county CT, soon as I turned 18 I was GONE, too damn cold up there and too many kids with the feeling of self entitlement and no desire to leave their home town to strike out on their own. Not that Maryland is much better, voted the rudest state in the country and I believe it. Alright time to step off my soap box. Looks like I should have stayed a little longer to learn how to keep my car cool haha
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
I just read on a few forums that guys just put a trash bag over the bag of ice and then put a towel down on the intake manifold to catch any sweat from the bags. Has anyone tried dry ice?
*edit* heres a place I found that sells it in BG
438 State Street
Bowling Green KY 42101
United States
http://www.homecityice.com/
438 State Street
United States
438 State Street
United States
438 State Street
United States
I remeber picking up a solid .2's on my L98 tpi car just from ice and running without the two air filters. Yes I do know the dangers of running sans filters. lol
#32
Removing the pistons and rods to soak them in a cooler seems like too much work for me, I think Ill just put dry ice underneith the intake manifold after each round and then bolt the intake down on top of it. Or I could just put some ice water in my windshield washer fluid container and run the windsheild nozzles in front of the blades of my throttle body.
![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
#33
Removing the pistons and rods to soak them in a cooler seems like too much work for me, I think Ill just put dry ice underneith the intake manifold after each round and then bolt the intake down on top of it. Or I could just put some ice water in my windshield washer fluid container and run the windsheild nozzles in front of the blades of my throttle body. ![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
in all seriousness though I thought about rigging up a cooler full of ice distilled water and hooking up a pump and hooking it to the radiator and pump ice water through the motor in between rounds.... but thats too much work lol
#34
Ive already wired my electric waterpump and my fans to run any time the key is turned to the "on" position, so normally in the pits Ill just open the hood and let both fans run with the waterpump circulating the distilled water with Water Wetter and that cools the motor pretty fast with the motor off. I think Im going to try bags of ice on top of a towel on top of the manifold this time though in between rounds.
#39
I was just reading through the Street Stock rules and just want to make sure I am good on a few things:
1. Are LS1 lids allowed?
2. I have LTs, ORY, and an 18" magnaflow glasspack which exits behind the front seats. Is this legal? It flows less than true duals or a cutout, so I dont see why it wouldnt be, and its not that loud.
3. I have FORD factory drum brakes on my 9", it says "factory drum or disk brakes allowed", they are factory, just not F body factory. Is this ok? They are heavier than stock so I dont see why it would be an advantage.
4. I dont currently have a driveshaft loop, do I really need to buy one right now? NEED THIS ANSWER ASAP
5. I lost/threw away/buried in the attic the plastic things that go at the top edge of the door frames, its part of the interior, but you wouldnt notice they are missing that easily. Also am missing my plastic sills that go on the bottom of the door frame. I have "Carpet and interior panels required forward of the package shelf. Must have headliner, sun visors, instrument panel, vents, heater controls, etc." Is this a problem?
GIZMO, are you the one who makes these decisions? Will any of these things be a problem? THE WORST THING EVER would be to drive 12 hours out there and be disqualified for missing some stupid plastic sills.
