Be afraid....
Old Sep 8, 2012 | 08:05 PM
  #61
94BlueZ28's Avatar
This is a sick build up for sure.... Question for you, What is the alluminum/sheet metal contraption on the driver side front corner for? Those headers are bad *** to, shed some light on how to get a set of those!
Old Sep 13, 2012 | 05:45 PM
  #62
TwoFast4Lv's Avatar
Baby Steps
Old Sep 13, 2012 | 06:23 PM
  #63
TwoFast4Lv's Avatar
Many People have been asking what is in it. I will try to cover some of it for everyone.
Engine
LTx Block 4.030 Bore with Cats Billet Splyde main caps and ARP Studd's
Eagle 4340 Indexed Crankshaft at .010/.010
Lunati 6in ProMod Rods
coated H bearings on all and coated Cam bearings
Wiseco Dome Pistons(14 To 1)
Hell Fire file fit rings
Thick Piston pins
Comp Cams Belt Drive
Milidon Std Volume Oil pump and custom built pick up
B&B 7Qt Race pan(fixed all oiling issues
ATI Harmonic Damper
Custom Comp Cam(listed earlier in thread)
Comp Cams Elite Solid lifters
Smith Brothers 8.400 length 3/8th by .120 wall push rods
T&D Shaft rockers
2.10 int/1.65 ext valves
Manley NexTek springs (410psi installed and 740psi over the nose)
Lots of titainium to match the NexTek springs
It is all sitting on a set of Brodix -18 High port/Spread port heads
Other goodies bolted to the engine
JakesZ28 Motor plate front and Speed Secrets Plate back
Areospace Vacuum pump
Jegs 140amp Alt
Moroso Mandrel system
FAST Crank trigger
Speed Secrets Cam pickup
Magnafuel 1000 fuel pump driven off the cam shaft
Hogans Custom Intake
Custom Nitro Daves Twin stage Direct port
TPIs Mono blade(for now)
MSD crank trigger Distibutor
Power Master XS starter
I made the headers my self. I spent about $550 in materials
2in stepped to 1 7/8th into a 3.5 merge collectors
Griffen Radiator
Meziere Frame mount Water pump
Custom built Surg Tank(that aluminum contraption thingy)
Feed by a Holley 1400 pump
Those are the basical mechanicals I can think of.
BTW I am on pain meds right now so If I screwed some thing up live with it
Old Sep 13, 2012 | 07:20 PM
  #64
bufmatmuslepants's Avatar
More info on the heads please, how much did it cost to convert them to LT? Are they ported? What do they flow? How much did they cost?
Old Sep 13, 2012 | 07:40 PM
  #65
TwoFast4Lv's Avatar
Yup They are ported. They flowed 340 out of the box and flow more now
I Have been spending money on them for the last ten years. I know there is over $3K in rockers, Valve train and porting alone
Old Sep 13, 2012 | 10:10 PM
  #66
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
Originally Posted by TwoFast4Lv
Nope Not Taners old one. But he does bring good beer
car looks great Ellis!
mine ended up in Florida
Old Sep 13, 2012 | 10:24 PM
  #67
TwoFast4Lv's Avatar
Thank for the words Tanner man. I am trying
BTW WHY In the hell can't Accell just put "DK BLUE wire at K2 goes to coil or MSD"????? Instead of me looking for two hours!
Old Sep 14, 2012 | 12:21 AM
  #68
Wicked94Z's Avatar
I coulda told ya in 5 sec from memory
Old Sep 14, 2012 | 07:19 AM
  #69
z_speedfreak's Avatar
whats your future plans for the TB Ellis? amazing craftsmanship on those headers btw
you can get sbc heads converted for around $400
Old Sep 14, 2012 | 11:18 AM
  #70
TwoFast4Lv's Avatar
I plan on going up to a 1,600cfm Cobra TB. We will see after testing. Word has it I will be maxing this one out and start drawing a vacuum again through the TQ peak
Old Sep 14, 2012 | 12:16 PM
  #71
lt1slowz28's Avatar
Max effort-esque project build with a eagle crank... why haven't the naysayers chimed in yet?!
following the build and I am constantly finding myself scratching my head thinking "why didn't I think of that?".
Old Sep 14, 2012 | 12:36 PM
  #72
TwoFast4Lv's Avatar
Crank was checked out to the extreme. My builder swears it will go 1,200RW. I was up for changing it but they swore I was ok
We will see
Old Sep 14, 2012 | 12:42 PM
  #73
jallen100's Avatar
Very nice man.
Old Sep 14, 2012 | 12:52 PM
  #74
lt1slowz28's Avatar
We will see
kind of how I feel about mine.
Mike said it will be fine for my goals, you as well as BigCat are running "eagle junk" and seem to be doing fine.
hopefully one day I can get around to checking the list of ideas for the car I have off. Never done an Fbody before and having people like you to guide the build are definitely a plus.
Old Sep 14, 2012 | 01:11 PM
  #75
Puck's Avatar
We will see
They have been over 1600 flywheel in SBCs.
Just gotta make sure someone who knows what they are doing goes over them first, not just take it out of the box and drop it in the block.
Old Sep 14, 2012 | 03:56 PM
  #76
fex77k's Avatar
I have an eagle crank in mine, definitely have to make sure it is good from the factory. Other than that it has been fine.
Old Sep 15, 2012 | 02:58 AM
  #77
TwoFast4Lv's Avatar
I did a little more today. Moving around a littl more while trying to pass my Kidney stones :S
Nose is on for the first time since 2009. Head linght switch is wired and working fine
LOTS of room for Front facing Ram Air intake
Oh baby I think this is going to work out! I got some carbon work to do but I think I am going to like it!
Tomorrow it hits the ground and moves out side so I can clean the shop and move it over a bay
Old Sep 15, 2012 | 07:17 PM
  #78
SS MPSTR's Avatar
Nice build. While the run-down on the "build" sheet is a nice reference, we all should recognize that God is in the details and a lot of the things that will separate this from most lies in them. Again, stellar build!
Old Sep 15, 2012 | 07:28 PM
  #79
TwoFast4Lv's Avatar
Thank you for the words. You are 100% correct. It is hard to explain the hundreds of hours in all of the details that is for sure.
I have it outside today so I can clean the shop. I forgot how insaine it looks in the sun!
Had to roll it out on the jack. the front Susention is no where near set yet. It should come down 2in or so when it is done
Old Sep 15, 2012 | 07:44 PM
  #80
ZFreie's Avatar
Think the distributor will work better on top of the dash eh? Guess its in a better spot then the opti was,windshield will keep it from getting wet
