How to clean roller rockers?
Old Aug 25, 2012 | 05:19 AM
bufmatmuslepants's Avatar
Default How to clean roller rockers?
My used rockers are a little dusty and need cleaning before going on the motor, I dont have a "parts washer" I have a sink, should I just run them under the sink and then soak them in oil?
Old Aug 25, 2012 | 06:49 AM
96lt1m6's Avatar
I would use gas.... put a few at a time in a bucket shake them a bit pull out wipe them down then place in clean oil.
Old Aug 25, 2012 | 06:55 AM
warriorcustoms's Avatar
Brake & Parts Cleaner with a coffee can & old tooth brush works in a pinch
Old Aug 25, 2012 | 01:52 PM
Spartan7's Avatar
I wouldn't use water. Soaking in mineral spirits would be better.
Old Aug 25, 2012 | 02:48 PM
Rob94hawk's Avatar
Marvel Mystery oil, a lint free rag, elbow grease, soak them in oil.
Old Aug 25, 2012 | 02:55 PM
Monzsta's Avatar
I second the gas.
Go find an antifreeze or washer fluid jug, or hell, even a 1 gal milk jug and cut the top off. Go pillage some gas from somewhere, and plop them in there. If they're nasty sludgy let 'em sit overnight. The gas will eat off most all the sludge and carbon.. Blow 'em off with compressed air or just let 'em sit out in the sun for a bit on clean cardboard and oil them up.
Don't forget to not smoke while doing this. lol.
Once I had just dropped (literally) a gas tank and had covered a good bit of myself and the surrounding floor with gasoline when the semi-hot receptionist broad came into the shop on her smoke break. She walks right up to me with a lit cigarette while I'm yelling at her to go away! "Don't come over here, there's gas." "What?" (walks closer) "GO AWAY! There's GAS all OVER!!" "I don't understand...." (walks even closer) "YOU HAVE A LIT ******* CIGARETTE!!! I"M COVERED IN GAS!!!" "EEK!!! sorrysorrysorry..." (scuttles away)
Old Aug 25, 2012 | 03:34 PM
Instead of compressed air im gonna have to use a leaf blower but that sounds good.
Old Aug 25, 2012 | 09:32 PM
LoL You might be a redkneck IF Lmao If it works do it
Old Aug 25, 2012 | 10:03 PM
SS RRR's Avatar
Village Troll
Let them soak in mineral spirits. Dry them out and then soak them in oil.
Old Aug 26, 2012 | 04:16 AM
turtle93's Avatar
I have wounder the same thing so thanks for asking one other ??? would an ultrasonic cleaner hurt the rockers at all
Old Aug 26, 2012 | 07:42 PM
BIGCAT7274's Avatar
personally i never wash my lifters or rocker with anything. wipe them clean and drop them in a can with clean oil.
Old Aug 26, 2012 | 08:05 PM
TwoFast4Lv's Avatar
Carefull!
Old Aug 26, 2012 | 08:17 PM
gregrob's Avatar
Just dusty... Spray them off with brake kleen then soak in oil.
If they were sludged up I would soak in chemtool B12 then dry and oil
