problem changing fuel filter
Old Sep 18, 2012 | 10:08 PM
25thhawk's Avatar
Default problem changing fuel filter
Changed the fuel filter on my 94 firehawk and when I took the filter out, fuel just kept pouring out of the hose, had to put the filter on while it was still flowing. WTF! never saw that before. It is extremely low mileage, what could it be? Thanks
Old Sep 18, 2012 | 10:18 PM
shbox's Avatar
It seems like it won't stop, but it will (or should, LOL).
Old Sep 18, 2012 | 10:33 PM
25thhawk's Avatar
Haha, no literally, I coulda drained the gas tank. I waited and easily had 2 or 3 quarts in a drain pan. Is there a check valve in the pump that could be bad? Thanks
Old Sep 19, 2012 | 02:13 PM
supernaturalta's Avatar
I'm assuming you relieved fuel system pressure first, right? I just changed mine last week, and very little fuel came out of it. Another thing I can tell you is that I'd think that less fuel would come out if you let the car sit for awhile before the swap instead of doing it right after having it running.
Old Sep 19, 2012 | 03:31 PM
25thhawk's Avatar
Yes I relieved the pressure before starting. Car was not running for atleast a week before I changed the filter. It wasn't shooting out like it was under pressure. It just kept pouring out like there was nothing to stop it.
Old Sep 19, 2012 | 10:07 PM
KFtransam's Avatar
That's what fingers are for
Old Sep 26, 2012 | 12:50 PM
25thhawk's Avatar
haha, yeah, i got it back on. But if there is possibly a problem in the tank I would like to fix it before it completely breaks. Should be easy to drain the gas before I store it for the winter tho.
Old Sep 26, 2012 | 01:14 PM
RamAir95TA's Avatar
Why would you drain the tank before winter?
Old Sep 26, 2012 | 01:20 PM
CamaroRacing12's Avatar
if anything you want to have some fuel in there
Old Sep 26, 2012 | 01:44 PM
25thhawk's Avatar
empty and refill full with fresh gas. Car has only 82 miles on it. I never use a tank of gas. I end up using it in my snowblower.
Old Sep 26, 2012 | 01:56 PM
RamAir95TA's Avatar
Better to store the car with a full tank of gas rather than an empty tank.
Old Sep 26, 2012 | 02:02 PM
unioncarpenter84's Avatar
haha need to drive the car only 82 miles thats crazy
Old Sep 26, 2012 | 03:03 PM
25thhawk's Avatar
yeah, the low miles comes with its own set of problems, no doubt about that. I got 2 other lt1 cars tho, so that provides the fix.
Old Sep 26, 2012 | 04:56 PM
any modded ones
Old Sep 26, 2012 | 05:04 PM
how do u relieve the pressure just take the gas cap off is tht it?
Old Sep 26, 2012 | 05:59 PM
RamAir95TA's Avatar
Take off the gas cap then relieve the pressure on the fuel rail via the Schrader valve.
Old Sep 26, 2012 | 06:38 PM
25thhawk's Avatar
I relieve pressure from the schrader valve. I didnt take the gas cap off. But I never have when changing a fuel filter.
Modded ones. Lightly. My 95 firehawk has a rebuilt motor, nothing special, small cam, roller rockers. My 25th TA has an intake, and some cosmetic stuff. My 98 SS is my project car. HCI 430rwhp. Not much left that is stock. lol
Old Sep 26, 2012 | 06:41 PM
ya im gunna change mine tomrw the car stutters a little bit just cruzing at 2500 rpm
