Short belt length for bypassing A/C and P/S?
Old 09-19-2012, 12:25 PM
BSmiff's Avatar
Default Short belt length for bypassing A/C and P/S?
Headed to the track on the 6th and just wanted to get a little extra out of the stocker. Anyone got a length on the belt? I haven't checked the routing to even see if I can do it.
Old 09-19-2012, 01:39 PM
shbox's Avatar
LS1Tech 10 Year
Not possible with the way the pulleys are aligned.
Old 09-19-2012, 01:42 PM
BSmiff's Avatar
So what else could I do to drop a couple tenths? I'm at 14.15@97 MPH right now. Bone stock with K&N CAI.
Old 09-19-2012, 01:59 PM
Dave357LT1's Avatar
Remove everything! Get ur tools and a sawzaw! Search the weight reduction threads.
Old 09-19-2012, 03:03 PM
BSmiff's Avatar
Back seats Jack rear tire sway bar.
Old 09-19-2012, 03:26 PM
RamAir95TA's Avatar
Don't get carried away with the weight reduction. Removing the rear tire will certainly slow you down!
Old 09-20-2012, 10:18 AM
sweetbmxrider's Avatar
Good advice. Don't do weight reduction if you want to go faster in the 1/4 mile.
Old 09-20-2012, 01:30 PM
RamAir95TA's Avatar
What...you go faster if you remove your REAR TIRE? I've been doing it wrong for so long!?
******* sarcasm, people.
Old 09-21-2012, 10:25 AM
WHOA! Easy tough guy. Don't get carried away with the SARCASM!
******* internets, people.
Old 09-21-2012, 11:41 AM
muddyjimmy's Avatar
I would also leave the rear tires on.
You could just remove the belt for the track. If you can charge a little between runs you will be fine.
Old 06-12-2013, 06:37 AM
BSmiff's Avatar
Bump this back up to the top.
When you guys get rid of your A/C and/or P/S how are you routing the belt? I can get rid of both those and bring a battery charger with me to the track to eliminate the alternator. Just looking for some info on people with race-only belt setups.
Old 06-12-2013, 07:15 AM
ThoR294's Avatar
Probably need some pullies in place... the belt can only be routed a certain way.
Old 06-12-2013, 03:09 PM
ramair96ws6's Avatar
A/c removed is a 1LE pulley from paradise to remove both you are working with mad man or another vendor for an Alternator relocation setup.
Old 06-12-2013, 03:25 PM
KW Baraka's Avatar
Originally Posted by BSmiff
......When you guys get rid of your A/C and/or P/S how are you routing the belt......
Personally, I like my AC and PS.
But if you manage to delete them, how much do you REALLY think you'll improve your 1/4 mile times by?
KW
Old 06-12-2013, 04:26 PM
96capricemgr's Avatar
You know it is really common on LT1s to just pull the belt for a few passes. You do realize the WP is not belt driven right?
Old 06-13-2013, 01:31 AM
BSmiff's Avatar
Interesting. I've never heard that done. What all is belt driven? PS, AC,___? I can do without all of that stuff temporarily.
KW to answer your question I honestly don't know but them little bits add up to a lot. I'll do the obligatory temp weight reduction and pull the belt to create a control that I will do every time out to see consistent gains. If it gains me a few numbers it will be a success. I'll even do a back to back for you guys to see real world results. Headed to the track on the 30th.
Old 06-13-2013, 07:08 AM
ThoR294's Avatar
and alternator. thats it. wpump is cam driven, AIR is electric, brake is vacuum...
Old 06-13-2013, 12:20 PM
BSmiff's Avatar
Nothing wrong with that. I will get me a battery charger so I can run beltless. Thanks guys.
Old 06-13-2013, 07:45 PM
You can make a few passes before needing a charge if the battery is good so no real need for a charger, just make every 3rd or so pass with the belt.
Probably net you a tenth.
Old 06-13-2013, 08:51 PM
joelster's Avatar
LS1Tech 10 Year
If you have a lightweight battery, it won't even make 1 full pass with a burnout on an EFI car. A full-size battery would probably be fine like other guys have said.
Quick Reply: Short belt length for bypassing A/C and P/S?
