Boost?
Do you intend to intercool or spray alky or anything?
What are you doing for heads and cam?
He sprayed alky over 9psi and had an intercooler took it to 11-12psi and the day I met him ran 12.8 with a best ever of 12.5 at 107mph. 2800stall Vig and 3.42s so decent setup for a mild turbo.
To put that in perspective my old heads/cam setup, AI 190cc heads, 226/234 cam 3400 Edge and 3.73s would run 12.7 at 108ish on STREET TIRES with the slicks and tools in the trunk fully heat soaked after a 150mile drive to the track.
Point being trying to make big power with boost on an otherwise stock longblock is a lesson in futility. I know LS guys do it but their heads/cam are a lot better to start with and tuning wise their ability to use 2-3BAR MAPs is HUGE in making it all work right.
I know a turbo seems like the easy way to make bug power, but IMO at least on an LT1 if you don't support the turbo right your car will cost more to build and be slower than a good heads/cam setup.
