best place to buy LT4 heads...
Old Apr 9, 2004 | 09:51 PM
Vendetta's Avatar
Default best place to buy LT4 heads...
probably gonna be investing in some heads soon, where's the best place to buy LT4 heads/intake manifold?
Also, anybody in Jersey know a good shop that could port them for me?
Old Apr 9, 2004 | 10:35 PM
TwoFast4Lv's Avatar
Scoggin dicky(sp) has the best deal on the whole kit as cheap as just heads from others
Old Apr 9, 2004 | 11:36 PM
Vendetta's Avatar
Do they have a place online I could buy from?
Old Apr 13, 2004 | 04:19 AM
blk~2000~Z28's Avatar
They are a sponsor ----->
http://www.sdpc2000.com/
Old Apr 13, 2004 | 05:30 AM
RacinLT1's Avatar
Might want to look up Jersey Cylinder Heads or Headworks in jersey. both do good work.
Old Apr 13, 2004 | 06:47 AM
OneMeanZ's Avatar
Could you expect good power by doing this?
Old Apr 13, 2004 | 01:00 PM
Vendetta's Avatar
Well, they will be ported by a local shop, which should give me some crazy good power gains considering that I'm still on stock heads...
Old Apr 13, 2004 | 01:19 PM
OneMeanZ's Avatar
Most definetly, what about if I was to go for something like that, or would I be better off keeping the LT1 heads and porting those with a nice cam?
Old Apr 13, 2004 | 01:24 PM
Vendetta's Avatar
It depends, you'd get more power out of the LT4 heads just from their design, but it's all up to how much money you want to spend and how much power you want out of your car. To some, buying LT4 heads may not be justified in the price.
Btw, thanks a lot for the info everybody
Old Apr 14, 2004 | 12:47 AM
kevinb's Avatar
Definetly get the stock heads ported with bigger valves. Will definetly outflow stock lt4 heads by a large amount.
Old Apr 14, 2004 | 02:00 AM
Vendetta's Avatar
That's the plan... I'd like some AFRs, but I simply can't afford to drop 2 grand on a set of heads.
Old Apr 14, 2004 | 08:49 AM
Elysian's Avatar
I picked up my AFR LT4's from Flatlander racing for ~$1600. They have since raised their price: http://www.flatlanderracing.com/afr195cclt4.html. I'm not sure I reccommend doing business with them, because they bill your credit card before you ever get the heads. Anyway, after I received them (about 10 weeks later b/c AFR's are on backorder!!!) I put about another $800 into having them ported. But GM LT4 heads cost like $1200 new anyway. Then you get to spend, probably, the same $800 having them ported anyway. If I had to make an estimate, the difference between AFR LT4 heads and standard GM LT4 heads, after porting, should end up in the neighborhood of $400-$500. Is is worth it? I'll know for sure when I get a dyno graph.
Old Apr 14, 2004 | 08:44 PM
Vendetta's Avatar
GM LT4 heads are around $6-800 brand new... 1200 is what i'd pay in total with them ported.
