Twisted Axle Splines
Old Oct 19, 2012 | 11:18 AM
GIZMO's Avatar
Originally Posted by bufmatmuslepants
This is a poor example. That guy applied a bunch of HP to those axles. Add in the fact that the axle is pretty long and that is what you get. Axles are like everything else, you have to match them to the rest of the combination.
Old Oct 19, 2012 | 11:24 AM
StraightTimeStirrups's Avatar
Originally Posted by RamAir95TA
D'oh!
What are your thoughts?
It appears that they only place there is any twisting is where the splines are fluted! That area is obviously weaker and if the splines had been more fully engaged into the Spool Splines MAY NOT have failed. It seems to me that even though they say a minimum of 1" engagement is all that is required, having splines that long just leads to more potential for failure!
Joe
Old Oct 19, 2012 | 11:34 AM
96lt4c4's Avatar
Getting ready to say, I bet these are Moser axles. I am going with Strange.
Old Oct 19, 2012 | 12:26 PM
1961ba427's Avatar
Joe
I agree with this. Deeper engagement may have kept it from twisting since it only twisted in the unsupported area that is cut for splines.
Also....what people said about going to a larger spline is correct. 33 or 35 splines are larger in diameter and therefore stronger overall.
It's nice to hear you are still taking the car out and having fun with it even though it is for sale. (Can't believe it hasn't sold!!!)
Old Oct 19, 2012 | 12:30 PM
Wicked94Z's Avatar
Strange 35 splines doing great here! I'm sure taner is running 40 splines with his setup
Old Oct 19, 2012 | 01:00 PM
bufmatmuslepants's Avatar
I know, but the point was that he went with stranges after.
Old Oct 20, 2012 | 08:03 PM
wrd1972's Avatar
Originally Posted by 96lt1m6
Tq breaks ****!!!!!!
Fixd
Old Oct 20, 2012 | 10:12 PM
96lt1m6's Avatar
^^^^^^^^^^Lol, yes........ my mind said it^^^^^^^^^^
Old Oct 21, 2012 | 01:55 AM
gregrob's Avatar
Joe
Deeper spline engagement wouldn't do ****. Just think about it, the area at the transition of the splines being engaged are where they are twisting.
They are not twisting in the carrier, or snapping / stripping splines etc. It could have 2 feet of engagement and still twist at the splined area that is NOT engaged....
What WOULD help is for it to be solid where the splines are not engaged.
Or just have better materials all together.
Old Oct 21, 2012 | 02:43 AM
Wicked94Z's Avatar
^^Yea^^
Old Oct 21, 2012 | 06:57 AM
bowtienut's Avatar
Thank you.
Sheesh.....come on guys!
Old Oct 21, 2012 | 07:32 AM
  #32
1961ba427's Avatar
In my post, I was saying deeper engagement may have kept it from twisting because I was meaning that there would not have been the unsupported section of splines sticking out there. If that whole area was inside the spool I don't think it would have twisted. Perhaps I should have said "if the axle splines were not so long and if the axle had been a little bit longer with deeper spline engagement."
Either way, I'd make the move up to 33 or 35 spline axles now. More splines equal larger diameter and more strentgh. My 33 spline axles dwarf my stock 30 spline 12 bolt axles.
Old Oct 21, 2012 | 07:38 AM
  #33
bowtienut's Avatar
Less exposed splines would only make for a less dramatic picture.
The degree of total twist is all that would change; the critical material damage and the failure point is going to be right at the spool engagement point regardless.
Yes, the fix is simply moving up in axle size.
Old Oct 21, 2012 | 07:43 AM
  #34
1Fast94's Avatar
I would go ahead and run that axle because it likely has already twisted as much as it's going to, is not bent and is comfortable now. I also do speak from experience, having sheared off several.
Old Oct 21, 2012 | 07:48 AM
  #35
1961ba427's Avatar
I thought about that too, but wasn't going to say it outloud. LOL All of that twisting may have happened the first time you took it to the track. I'd be tempted to mark it and then make some more runs....pull it and check the mark to see if it twisted more. That would be the experimental way to go.
Buy the 33 or 35 spline axles and spool and sell your one good axle and spool to offset the cost some.
Old Oct 21, 2012 | 07:57 AM
  #36
bowtienut's Avatar
I thought about that too, but wasn't going to say it outloud. LOL .....
Now, we're all fessing up!! I'm sitting here thinking, "Dangit, Joe, it took years and hundreds of passes to do this. Why spend money on a new spool and axles when all you're gonna do is sell it anyway!"
I understand Mike's point. When the material moves, it work-hardens, so this axle has just as good a chance of survival as a new one of the same size/spline count.
Old Oct 21, 2012 | 10:22 AM
  #37
Paul Bell's Avatar
That's MISTER MODERATOR
Move to 35 splines. And Strange.
Old Oct 21, 2012 | 10:57 AM
  #38
TwoFast4Lv's Avatar
My problem with reinstalling it is what happen if the nose is in the air when it fails? Sorry I hate walls
Old Oct 21, 2012 | 12:16 PM
  #39
RamAir95TA's Avatar
35 spline it is guys. Fingers crossed.
But unfortunately the car won't be ready for LTX East Coast.
Old Oct 22, 2012 | 06:13 PM
  #40
Wicked94Z's Avatar
Originally Posted by bowtienut
Now, we're all fessing up!! I'm sitting here thinking, "Dangit, Joe, it took years and hundreds of passes to do this. Why spend money on a new spool and axles when all you're gonna do is sell it anyways"
:cancels order: :deletes thread:
