New lt1 owner wanting ideas
BUDGET BREAKDOWN ITEM PN COST Junkyard 5.3L motor, PCM, wiring harness
$449 Ebay 76mm turbo N/A $425 T4 turbo flange 14410 $26 1.75-inch U-bend N/A $25 2.5-inch U-bend N/A $27 3-inch U-bend N/A $37 2.5-inch flex joint 4556 $27 3-inch flex joint 46544 $32 Silicone coupler 2744B $59 Silicone reducer 2760B $15 2.5-inch V-band clamp and weld end N/A $26 3-inch V-band clamp and weld end N/A $38 T4 oil drain flange 2849 $15 -10AN oil line (3 feet) 230003 $21 -8AN oil line(3 feet) 230803 $16 1/8-to-4AN adapter fitting 10292 $4 3/8-to-10AN adapter fitting 10294 $5 O2 sensor bung 1194A $5 Turbosmart wastegate 0504-1001 $399 Turbosmart blow-off valve 0204-1001 $299 Turbosmart boost controller 0106-1001 $137 Ford SVO 42 lb/hr injectors M-9593-F302 $309 GM 2.5 bar MAP sensor 12614973 $53 GM LS6 valvesprings 12499224 $57 HPTuners software N/A $499 GM '01 LS6 camshaft 12560950 $183 NGK TR6 spark plugs (8) 4177 $16 Royal Purple 10W-40 oil (6 quarts) 01140 $48 TOTAL: $3,252
Read more: http://www.hotrod.com/techarticles/e...#ixzz2ALkcBTu7
sell his lt1 for $500 or so. pick up a ls k-member. Do all the work yourself. I think it could be done for under 5k
i gotta say im w pillarpod i realize that forced induction is not the most popular way of making hp on this sight but w his goals and a 8-10k budget it cld b dun now im talking cheap engine freshen and procharger nothing to make that stick to the ground that will b more yet i know this get said all the time but if and u do a nice stroked engine u will have 7k in it. And then u have heads intake all that other stuff and still only making 450rwhp maybe alil more. All these guys on here that do low 10s NA w this block r geniuses but they didnt do that overnite i guarantee theres yrs put into there cars to get to where they are now. Huge props to them its just more cost effective w boost.IMO...... or.....like the other guy said sell urs and buy the green one a proven dd that does that track time is amazing and u wiont dont do that urself for under 15k probobly more.
Ha it's not the way huh? We have guys on here with stock ls1 blocks with forged connecting rods and pistons, stock crank and stock 243 heads with d1 chargers putting down over 700rwhp. That's pretty cheap IMO!
Maybe if he sold the LT1 for $5k
and had another $5k laying around and did it on a super budget...
OP It really doenst take much to make these cars Fast. A rear end with 4.10's will make the car feel alot faster then how it is right now. Heads and cam on a healthy stock bottom end will run around $3-4k if you do the work yourself. 400+ to the tire is a damn good amount of power!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
