Rear End Blow
Old Oct 31, 2012 | 08:16 PM
GermanLSX's Avatar
Default Rear End Blow
I just blew my rear end attempting to do a burnout My theory wasnt the burnout, more of the high speed abuse it takes daily is why I think it blew. Its sitting in the driveway waiting to get towed. The ring and pinion completely exploded too many pieces to count. Should I upgrade in the morning or go with a stock replacement.
Old Oct 31, 2012 | 09:50 PM
warriorcustoms's Avatar
Order a 12 bolt or S60 & be done with it putting money into a 10 bolt thatll still break is just silly
Old Nov 1, 2012 | 12:06 AM
Wyocattech's Avatar
Strange 12 bolt here. Its nice because it still uses stock thru style bolts instead of four bolts like the moser.
Old Nov 1, 2012 | 12:07 AM
TDFDiesel's Avatar
Upgrade...
Old Nov 1, 2012 | 05:06 AM
RamAir95TA's Avatar
For 95% of people who haven't already upgraded the 10-bolt tossing the idea of simply upgrading to a $2500+ rear end isn't a possibility.
It is easy to spend someone else's money.
OP - if you don't have the change for a 9", S60, 12-bolt, etc., just have the rearend rebuilt. Add a girdle and hope for the best. It'll probably cost you $500+ - alot of money still but it will get you going again.
Old Nov 1, 2012 | 10:38 AM
speed_demon24's Avatar
If you are mechanically inclined you could do the gears yourself and save the money. That's what I did when mine blew, plus I know they are done right.
Old Nov 1, 2012 | 11:08 AM
noice's Avatar
Seriously, no one will tell you this until you actually spend $3000+ on a Moser to find out on your own. The four bolts suck.
Either replace it with a stock rear end or upgrade to a built 9inch.
Old Nov 1, 2012 | 11:09 AM
SS RRR's Avatar
Village Troll
High speed doesn't kill the differentials. It's shock to the driveline. If you want to make it last, ease up on the street abuse. These 10-bolts are pretty much made of glass. Part of the reason why these cars were so affordable when they were new.
