QA1 Rear Shocks... Single or Double adjustable?
Old Nov 9, 2012 | 08:59 AM
  #81
GIZMO's Avatar
Originally Posted by Longbob
There is only one spring rate that comes from GM for these cars that I am aware of so I use spacers to stiffen it up.
There used to be a bunch of different part numbers in the books. They had springs for six cylinders, convertibles, 1LE, LT1, etc. In about 1999 they went to one part number. I tried a bunch of different spring combinations. Gump has a 1995 Formula spring on the passenger side and a early six cylinder spring on the driver side. That way it still sits level. On my later builds I used aftermarket springs in different rates. It seems to work pretty good.
Old Nov 9, 2012 | 09:05 AM
  #82
Jeff400w's Avatar
Kyle, would you mind if I sent you a pm sometime?
I would like to ask you some stock eliminator questions.
I'm getting Tony's thread way off topic.
Old Nov 9, 2012 | 09:25 AM
  #83
CamaroRacing12's Avatar
no worries keep the questions coming i only benefit from them!
There is sooooo much to gain in suspension its crazy and to think i haven't even touched mine yet!
Old Nov 9, 2012 | 09:26 AM
  #84
Kyle how is the street manners with that spohn manual rack?
Old Nov 9, 2012 | 09:35 AM
  #85
i might be buying a chrommoly steering column with a quick disconnect should save 20 lbs
Old Nov 9, 2012 | 09:42 AM
  #86
Longbob's Avatar
Jeff,
Feel free to message me. I will help all I can.
Tony,
I am not sure about the street manners. I should qualify that all my comments are for the drag strip. Others can answer your question much better than I because I don't have any experience modifying these cars for street and/or street-strip.
Now, if you wanna talk Cummins diesels mods for towing/street performance than I can help you. But that is WAAAAYYYY off topic.
Old Nov 9, 2012 | 09:44 AM
  #87
Longbob's Avatar
I guess that am only looking at the '99 and up springs. I can have a custom one made to the exact rate I need, but this is working so well I just haven't gotten the energy up to have it done.
Old Nov 9, 2012 | 10:22 AM
  #88
1961ba427's Avatar
How could I find a listing of old part #'s and spring rates for different cars?
I have a 97 WS6 convertible parts/junk car. Wonder if those springs are very differently rated?
  #89
GIZMO's Avatar
I hear you. GM actually replaced all the part numbers in the book back then, so they only list one number for all applications now.
Old Nov 9, 2012 | 10:23 AM
  #90
GIZMO's Avatar
The stiffer springs are normally shorter and the coils have a larger diameter.
Old Nov 9, 2012 | 10:39 AM
  #91
1961ba427's Avatar
Yeah I work in GM parts and just looked up rear springs for a 95 and although it lists several different codes for the springs...they are all one number. The bad thing is finding a printed catalog would be tough. I have some GM parts catalogs for 75 to early 60's models, but that's it.
Old Nov 10, 2012 | 12:43 AM
  #92
Matts94Z28's Avatar
It's nice to see some good information being passed around in here! It's better than the "How to install an LS1 lid" threads for sure.
Once I get the new top end on my car I will be looking at redoing my suspension. Basically all I have that is worth a crap at the moment are my Stragne SA's and Spohn TQ arm. My cheap 50/50's have been doing alright in the back, but I really need to get a quality shock and a nice anti roll bar.
Not leaving very level at the moment:
http://youtu.be/mrQHoW5LjPU
Old Nov 10, 2012 | 09:00 AM
  #93
bufmatmuslepants's Avatar
Im very curious as to how my car is going to leave on saturday since it will be my first time hitting the track with my new rear setup and launching at 6000 rpm. I did it twice at 3000 2 months ago and cut 1.74. My car leans to the passenger side in the rear for some reason, always has. I feel like im going to be leaving ALOT on the table after reading this thread with my stock sway bar bilsteins and no airbag.
Old Nov 10, 2012 | 09:04 AM
  #94
1961ba427's Avatar
Since your car already leans to the passenger side and that's the side that needs more help.....jump under there and swap springs side to side. Maybe that will at least level it out some sitting still and help make most of what you currently have. All it will cost you is an hours work.
Old Nov 10, 2012 | 09:09 AM
  #95
SS RRR's Avatar
Village Troll
Depends on track prep as well. Usually Cecil is good with the compound. At the very least you can try an airbag.
Old Nov 10, 2012 | 10:07 AM
  #96
Or a childs football jammed in the spring like that turbo 82 fairmont had
Old Nov 10, 2012 | 10:23 AM
  #97
It wont matter much you'll be seeing my taillights by the 60ft mark neways! Hah!
Old Nov 10, 2012 | 10:25 AM
  #98
That is expected but ill run you down as i cross the line at 113 to your 108!
Old Nov 10, 2012 | 11:30 AM
  #99
We'll see! Hah!
Old Nov 10, 2012 | 04:04 PM
  #100
Longbob's Avatar
I about cracked a rib on the child's football idea! Hahaha! Dang that is innovative and funny.
You guys have a great website and participants. You are lucky to have guys like Gizmo/Gump to bridge the gap between street cars and pure drag cars.
