QA1 Rear Shocks... Single or Double adjustable?
I figured I would mention it since a "bolton" car in Mass. will likely be driven at low temps, maybe not the sub zero we get here but low enough to maybe ask around and see if the same complaint applies to the f-body.
I dont see myself changing rear shocks anytime soon, but I will be going to double adjustable fronts so I can adjust the compression of it.
Here is a video of my car at cordova, the first pass I had the fronts too soft and you can see when it came down the front shocks just gave to much, a DA shock really could've saved me there. I tightened the fronts and kept it down. The Rears were set at 8
Sounds like single adjustables are the way to go. I'll be buying a used set today.
shocks, 4.10's, SFC's won't be installed for the cecil race but will be for next years shootout.
Granted, my car runs on the bitter edge due to rule restrictions, but it also one of the best working stock eliminator cars. I would rather have the ability to adjust and not need it than to not have it and need it.
http://www.facebook.com/events/390973970955850/?fref=ts
Beers are on us!
