LT1 nitrous recommendations
Biggest XE grind is 227/233 duration, .560"/.569", 114
Biggest X series grind is (TN-236XH) 236/244 duration, .608"/.613", 112lsa
SRP pistons are extremely strong. Budget, but not because they're not strong pistons. They're rather heavy (less intricate machinework) which keeps costs down, and strength up
Consider taking a look at this intake. Your getting to that point. Complete with new fuel rails to feed all the nitrous you'd want. 300+cc. BIG.
http://home.wideopenwest.com/~squinn0039/ltx.html
Honestly, as far as the cam, I would swap in a 224/236 xe (at least). what compression are you at with the srps?
Here's a granddaddy cam list
http://www.cmotorsports.com/engine/l...ft-design.html
TS-224XH 224/236 duration, .605"/.622", 114lsa
Smaller duration, more lift.
