lt1 mods
Old Jan 2, 2013 | 02:56 PM
StoneCold T/A's Avatar
Default lt1 mods
95 t/a new headers cam exhuast quick shift trans...i already the basic things out of the way now i can get into addin some horsepower....any ideas on how to get me to around 435 or 450...i cant decide on some things lol need help
Old Jan 2, 2013 | 03:41 PM
96capricemgr's Avatar
What cam?
Is it tuned?
Are you looking for that number at the tire?
How quick do you want to run at the strip?
Or is road racing your thing?
What is a
quick shift trans
Is the pcm reprogrammed?
Old Jan 2, 2013 | 04:53 PM
RamAir95TA's Avatar
435-450 at the wheels or flywheel?
Old Jan 2, 2013 | 04:54 PM
Originally Posted by 96capricemgr
What cam?
Is it tuned?
What is a ?
l14 hot cam...its a quick shift transmisson auto with 3.73 gears...i would like to get low 12s by spring
Old Jan 2, 2013 | 04:58 PM
RamAir95TA's Avatar
Explain what a "quick shift transmission" is.
A full bolt-on car with good suspension, traction, hotcam, and good tuning should be able to run mid-low 12s assuming you have good DA and a have a good track.
Old Jan 2, 2013 | 05:13 PM
its just a quick shifter disc that normal
Old Jan 2, 2013 | 05:15 PM
I was thinking about getting done some work on my heads new intake and bigger throttle body maybe around 58mm new fuel pump and some injectors
Old Jan 2, 2013 | 05:22 PM
The available Edelbrock intakes are NOT an upgrade, guys have made over 420rwhp with stock intakes just opened up for a 58mm TB.
That said if you do heads I would redo the cam. If you are going to put work into the heads why not give them some lift to work with.
This statement
is gibberish.
You need a quality stall converter if you want an A4 car to be quick.
Guys have gone high 11s with probably only 320rwhp in very well setup light cars.
From the little you have said it sounds like you are very new to this and need to either slow down and wait awhile before you make mistakes or find a local mentor. Most guys are willing to help those less experienced IF the guy wil willing to be helped.
Old Jan 2, 2013 | 05:25 PM
93 LT1 Vette's Avatar
AI or LE heads ,1.6RR to bump the lift on your cam and a quality tune. Even with that, your current cam maybe to small to make your number at the wheels.
100 shot would put it in the ball park.
Old Jan 2, 2013 | 05:30 PM
This statement
is gibberish.
actually not gibberish at all the quick shift in is the stall thats in my car making it shift quicker...not a newbie dude
Old Jan 2, 2013 | 05:44 PM
RamAir95TA's Avatar
It's gibberish. The stall converter has absolutely NOTHING to do with how fast the transmission shifts.
The vocabulary and content of your posts do indicate that you are fairly new to this - no offense.
I would just refine your current combo. Don't fix what isn't broke.
