zz3 a4 questions
a stall converter, 3.73/4.10 gears maybe deeper, suspension upgrades, tires you can hook on, weight reduction, nitrous ... you possibly could get into the 7's depending on how much nitrous and weight reduction you wanna do
7.90's 1/8 is only 12.6 1/4. A stock cam would get you there if the rest of the car is working right, and the ZZ3 is a helluva lot better than stock.
You NEED a decent torque converter!!
Granted the ZZ3 cam is not modern or something I would have recommended but it is capable of a lot more than you are getting from it. The FWHP number is not that big especially if it was a "happy" dyno, one "reputable" LT1 crate engine vendor sells 440hp strokers that put 330 to the wheel and run slower than heads/cam cars.
I would have RUN if a guy I was asking to port LT1 heads told me to do a ZZ3 cam in this day and age though...............
Having run one and not regretting it I MIGHT run one these days if the heads were 100% stock and I got the cam from free and had the engine apart for something else. I ran that cam something like 10 years ago when I was putting over 20K miles a year on the car. Cams and springs have come a long ways, as have heads, and I put it in to replace a smaller b-body cam not the larger f-body cam.
