What solid rollers
I have never heard any complaints on the Crowers. Any lifter that is a HIPPO is the best to run. I run Iskys, but they are huge and probably pretty heavy. The one advantage is they are very tall so I can run a very short 5/16" pushrod.
What cam are you thinking of if you feel like sharing? I take it you are going to use the stock PCM?
Here's a vid going 45mph in 5th gear with 3.73's.
For that mild cam Comp Endurex will be plenty...I don't see a reason to spend crazy $$$ on Morels with a 23x cam that will never see past 7k. Lots of success with them on much more aggressive motors that see street duty on more aggressive tech forums like YB and speedtalk.
They are HIPPO lifters that can be run on the street.
and throw some spray in the mix (200+ shot). Might go forced induction in a few years but going to worry about that another time. An 87 Iroc that had the poor little L98 and selling it. PM for interests. Last edited by 396LT4IROC; Feb 1, 2013 at 12:17 AM.
Actually, duration and lobe centers have nothing to do with how good your lifters need to be. It's more lobe profiles which dictate spring pressure. But, why not buy the tough lifters and not worry about it?
I'm sure somebody uses Morel lifters (they have to sell lifters to stay in business, right?), but nobody I know of. They are probably great. I know what three of the top NHRA Competition Eliminator (10,000 + RPM SBCs) and Super Stock engine builders use: Jessel & Isky. Comp engines mostly Jessel. One uses what used to be Crane.
At least two (I know for sure) of the fastest NHRA Pro Stock guys use Jessel.
The key to making a solid roller live is idle in traffic oil pressure, valvetrain setup properly with the correct springs and a good oil . I ran Shell Rotella in the car.
With the advent of recent lobe technology I really see no reason to run a solid roller on the street unless its a over the top max effort engine looking for that last 20-30 hp.
