passenger side cherry red manifold?
Old Feb 13, 2013 | 04:52 PM
teal94z281989's Avatar
Default passenger side cherry red manifold?
ok so my passengers side exhaust is getting red hot on idle. after i just found out my iac valve is bad heres another reason??? It never ends. Can some one tell me what could be causing this? Its only the back of the passengers side exhaust, The drivers side is ok, thanks everyone.
Old Feb 13, 2013 | 07:22 PM
nitrous2fast's Avatar
too lean on those banks...
Old Feb 13, 2013 | 07:40 PM
Could it be from my rockers not adjusted properly? I kno i dont have a vaccum leak and my fuel pressure is great along with my injectors. Im gonna try to adjust them tomorrow and see what i get.
Old Feb 13, 2013 | 08:03 PM
F0x Slaughter's Avatar
Did you do anything with the PCM?
Old Feb 13, 2013 | 08:35 PM
Have you had your rockers off recently or changed them?
Old Feb 13, 2013 | 08:53 PM
ThoR294's Avatar
that means that side is not firing properly. check over everything on that side... could also be running pig rich (if there is a cat on that header, the cat can glow if too much unburnt gas goes into it)
Old Feb 13, 2013 | 10:11 PM
nothing was done to pcm
Old Feb 13, 2013 | 10:16 PM
yea i had rockers off recently and before my head gasket blew this never happend. I changed gaskets and put everything back together
Old Feb 13, 2013 | 10:26 PM
SoxXpupPeT's Avatar
You might have a vacuum leak causing a super lean condition. Ive seen that happen on gen I small blocks. The guy didnt torque the head or intake properly and he melted all 4 of his pistons on one side of his engine.
Old Feb 13, 2013 | 10:35 PM
no vacuum leaks car runs great other than the back of the exhaust getting cherry red hot.
Old Feb 14, 2013 | 03:04 AM
NewOrleansLT1's Avatar
Happened to me when I first got my Z28. The problem seemed to work itself out for some reason...
Old Feb 14, 2013 | 06:03 AM
bowtienut's Avatar
Holy ****, come on guys, read what he said. ThorR is the only one who thought before typing.
"the back of the pssgr side exhaust" a misfire on #6 or #8 plain and simple.
No need to complicate it.
Old Feb 14, 2013 | 07:08 AM
ok so i rechecked my wires and there ok. There is no ses light on and the car runs great. Doesnt feel like there is a miss,and its really only # (8) that gets hot like that. The rest are fine.
Old Feb 14, 2013 | 08:02 AM
bowtienut's Avatar
How did you check the wires? A good resistance reading doesn't mean the wire is good.
If you can't spot anything obvious with either end or with the insulation, replace the #8 plug and wire. That will probably fix it; if not, I'd say it's a toss up of:
1. the #8 connection inside the Opti
2. #8 injector dribbling when it's supposed to be closed (would be most noticeable at idle).
Old Feb 14, 2013 | 08:11 AM
munn79ta's Avatar
i had this happen to my 98 after i went to start it after winter. the battery was dead...then i noticed that my headers were getting hot. i shut the car off and then let the battery fully charge started it again then the problem disappeared. ive noticed it does it everytime the battery dies... second winter and crappy battery. after i shut it off and restart it, it never happens again.... only thing that makes sence to me is computer relearning a/f??? but who knows.....
Old Feb 14, 2013 | 08:26 AM
if the wire was bad wouldnt u think the car would have a noticable miss ? I checked all my injectors berofe i put them back on the car by putting gas in them and letting it sit for an hour and the gas never went down. also its a brand new accel cap and rotor on the opti
Old Feb 14, 2013 | 09:22 AM
guppymech's Avatar
Is the EGR pipe connection to the passenger side manifold tight?
Old Feb 14, 2013 | 10:35 AM
I think i found my problem. My belt was rubbing against my #8 wire and made a hole in it so im going to change my wires. is there a bettter way to place the plug wires that go against the pulley bracket? Also what wires should i get for a decent price?
Old Feb 14, 2013 | 10:39 AM
I did a egr delete. So i no longer have that pipe.
