new tune new problems
Testing the icm when cold would then yield results saying it's fine, but when it heats up because of the engine the malfunctions start to happen. See what I'm trying to say?
Reinstall the icm, space it from the head with washers, and see if that solves your problem.
Maybe you already tried this, but going off your posts, you only took the icm in to test it and never tried installing it and spacing it from the head and seeing if that solved your problem.
1) Tuning the PCM will never fix a problem like you have.
2) Never take a coil, module, anything like that to a parts store for testing. There is no valid bench-top test for those components.
3) Don't buy anything from Autozone that has a wire going to it. LOL
I then slightly bent all pins within opti harness, opti, and icm ..hasn't died again since. I also found a poor Harness ground prior to fixing daily constant engine dieing issue.
