ltcc
Old Mar 3, 2013 | 02:12 AM
1toofastlt1's Avatar
Default ltcc
Where can I get a ltcc kit? My opti burnt out so I figured it would be a good time to change over. Is there any downside to the ltcc kit?
Old Mar 3, 2013 | 02:25 AM
Alex94TAGT's Avatar
What precisely "burnt out" in your current Optispark?
The LTCC still requires a functional optical sensor within your current Optispark. If your optical sensor is shot, then an LTCC won't help you -- you'd still need to install a replacement Optispark (or at least a new optical sensor) to get the LTCC to work.
http://www.bailey-eng.com/LTCC.html
_
Old Mar 3, 2013 | 06:13 AM
96capricemgr's Avatar
and if it was just the cap and rotor that are shot those are $100 TUNEUP ITEMS
Old Mar 3, 2013 | 10:05 AM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
If your opti truly is bad, and your wanting to go coil on plug you should go 24x conversion.
By the time you bought coils and everything for the ltcc, the ltcc, and a quality opti you will be really close to what the 24x conversion costs.
The 24x completely does away with the opti.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Mar 3, 2013 | 11:17 AM
RamAir95TA's Avatar
Not to mention the LTCC still needs a functioning optical sensor for it to work properly. It is NOT an opti-delete kit.
Old Mar 3, 2013 | 11:23 AM
I understand that I need a working opti. I think my rotor broke but I havent pulled it apart yet. I want to do coil per cylinder because I run a 6al-2 msd box and I hear that its hard on opti to run the more powerful spark through it.
Old Mar 3, 2013 | 03:11 PM
RamAir95TA's Avatar
The next question is what are you using the 6AL-2 for? If you don't NEED it it's certainly no benefit. The stock ignition system is PLENTY powerful for just about any application. Adding an aftermarket ignition often complicates things on non-NA/non-boost applications with zero benefit.
Old Mar 3, 2013 | 04:24 PM
I have a 383 with a v7 ysi running about 15 psi. I also like the 2 step for more consistent launch with the 6 speed.
Old Mar 3, 2013 | 06:36 PM
LS1Tech Sponsor
In any application that someone is pushing that kind of boost or more I ALWAYS recommend going 24x, the tuning capabilities will benefit you greatly.
If your opti is bad, then you can go 24x for slightly more than doing the opti and ltcc. However, the 24x will most likely save you in tuning costs, so it should even out.
__________________
1-888-467-4491
