Starting to bring the Z back to life (IT LIVES)
#44
The car is all done, and I've put about 80 miles on it so far. Runs like a dream! Only issues I have is the fit on my SLP lid to my SS hood is super tight, time to swap to a cowl hood. I also have a exhaust rattle on the xmember, I need to push the drivers side Y pipe on the collector a little more and make a bracket to hold the Y pipe up.
So far I can say the exhaust is a bit loud, but for now I'm content with it. Taking it to the track May first to get a base line of what it runs now on street tires, will go back as I add more stuff though. I'll post some videos up soon of it running.
#46
But with the SS hood I have it is a super tight fit, I'm going to trim the edge of the lid a little more and make some brackets for the radiator.
#47
So here is my finished product for now. I have plans to take car of a couple things this year and store the car for winter. I'm incredibly happy with how it runs and drives, no issues at all right now, aside from missing an exhaust hanger so the Y pipe rattles randomly.
I'll be making some radiator supports here soon to make the lid install look a little cleaner.
Plans for the future
Wheel/tire package 17x9.5 and 17x11's
suspension upgrades
VFN Sunoco style hood
SS spoiler
Tune
Full paint job
HID conversion
Window tint
Overall just making a really nice 12 second cruiser out of the car. Might stall it and go for 11's later on. Here are some pics from today.
suspension upgrades
SS spoiler
Tune
Full paint job
HID conversion
Window tint
#51
Yeah, thats a cast crank problem. I would still have the 4340 stuff looked over and inspected by a professional, and balanced as perfect as possible. I run the 4340 eagle after snapping a cast eagle. no complaints yet.
#53
Well took the car to the track, made 5 passes with it. It was 82 and sunny out. Track prep was actually good at Milan for once. First pass was 13.7 @ 100.65 with a 2.0x 60ft. Best pass was my third 13.6 @ 101.80 with a 2.10 60ft time. All on 5 year old goodyear eagle gt street tires at 25 psi. Launched off the foot brake about 1k ish rpm's. Was hoping for lower numbers, but it's a good start I think.
#55
Now I have a misfire problem, at about 2100 rpms in overdrive on the highway it will stutter and miss, i can kick it out of OD and it will go away. It's normally only between 1900-2300ish and did not start till I got gas from a BP that ran out of 93 and 89 so I had to put 87 in.
I'm going out to pull the plugs and double check to make sure no wires are laying near the headers, but it's only that rpm range on the highway, in town under 2k it's fine.
Anyone got any ideas?
#56
So I've neglected this thread for a very long time. Taking the car back to the track finally this year to see where it's at after all the fun **** breaking.
Exploded a trans a few months ago, which lead to me adding my wideband o2 while it was apart. Only to have the plug fall out of it's holder and break wires on the harness. My dad helped me work on the car and he mixed up coolant lines to the rad and i had overheating issues to figure out.
The car has over 217k now, runs pretty good now if I say so. Rear main still leaks... Working on finishing up the tune I've been doing. New wheels/tires, someone stole my LM2 off the car, so it's been on an open Y pipe for a year and stupid loud. Knock sensor went out, causing the tune to do all sorts of wacky stuff, and I still have random key issues and the security light. I have my resistor setup ready to be soldered in, just have not done it yet.
Motor comes out in a month or so to fix 2-3 head bolt holes for the headers, clean the heads up and maybe open them up some. New rear end, with 3:73's, and maybe an exhaust.
I'm also looking into lsx shortblocks for a 6.0/408 build.
#57
It hooked once last night, new PB with nothing changed from last year mod wise, just a revised tune by myself (which still runs rich at WOT and it's not taking changes....)
Track DA was 978 give or take, and prep was ok for Milan Dragway I suppose. Leaving the line on the foot brake, no revs on the converter and a stock rear end that's on its way out.
I'd like to get the car tuned professionally after I get a few things fixed. Maybe aim for 12's with bolt ons and DR's.
Since the motor comes out in around a month, I've been putting a to do list together... and it keeps growing.
Motor wise
new rear main
heads have to be fixed, broken exhaust bolt and one stripped
re inspect the bottom end, maybe a rebuild while it's that torn down
I'd love to put a cam in it, but funds don't seem to be allowing it yet
new motor/trans mounts
OTVC plug wire kit
drivetrain
install my trans temp gauge
LS1 driveshaft
new rear end (probably just a 10 bolt with 3:73's) mines cracked....
Finish removing the Ebrake cables/brackets etc
misc
new accessory bracket, or fix mine. Ps bolt stripped.
Re do my lid setup to use the ls1 plastics like I should have from the start.
new catback, my LM2 got stolen
new band clamps, 2 of them rattle on my Y pipe...
PAINT!!! it needs a paint job so bad right now. Hoping to have the hood painted at the very least, but I need to find a rear bumper that's not broken too.
Seems like a lot, but it's really not that bad.
Motor wise
new rear main
OTVC plug wire kit
drivetrain
LS1 driveshaft
misc
#59
TunerPro Rt, and Datamaster for logging. I have a Uego i was able to watch during each pass. Left the power inverter at home so no logs just visuals for afr. I have my afr/coolant table 0'd and my afr/rpm table starting in the 8's dipping to low 7's for the table values and the car still hit 11's afr wise up top.
Here it is making it's runs.
