New Wheel Combo
Old Mar 29, 2013 | 02:51 PM
F0x Slaughter's Avatar
Default New Wheel Combo
Well shes dirty, she just got rolled out of the garage.
Trans is still not back in.
Have to do BFH for the slicks out back.
Might have to do some trimming.
Who is running 28in slicks? Anyone got pictures of exactly what needs to be cut?
Old Mar 29, 2013 | 02:54 PM
draggin97s10's Avatar
no input on 28's but your car looks good brother
Old Mar 29, 2013 | 03:02 PM
Thanks.
Just finished double adjustable rear shocks, front double adjustable coilovers, S60 with 4.10s, have a Spec Stage 3 in just need to put the trans back in, UMI tunnel mount Chromoly torque arm. Also converted to 6an fuel lines from rail to sender.
Old Mar 29, 2013 | 11:35 PM
myltwon's Avatar
How wide are the wheels?
I ran a 28" tire on 15x8, just had to roll the fender lip because it was cutting the tire. Made a small cut along the paint so it wouldn't crack, then had some friends weigh down the rear while we rolled a baseball bat at an angle between the wheel well and tire.
Old Mar 30, 2013 | 12:12 AM
LT1's Avatar
LT1
depending on how wide the tire is lots of bfh, roll fender lip, and rear lower control arm will help.
Old Mar 30, 2013 | 11:05 AM
transbird95's Avatar
More pics of car please! She looks nice!
Old Mar 30, 2013 | 03:12 PM
The wheels are 10". Doesn't look like I need to roll the fender as my BS is 7.5". I did BFH fender wheel today no more rubbing. Have about 1/2" in front and 3/4" in the rear. So I think I am going to get adjustable LCAs (Have non right now) and kick the axle back a little bit and trim the bumper.
Old Mar 30, 2013 | 03:15 PM
Engine bay still needs work but its a start.
Old Mar 30, 2013 | 06:17 PM
SS MPSTR's Avatar
cut a ton, and used adjustable LCA's to help center the rear.
Old Mar 31, 2013 | 10:56 AM
Front and rear gap on the 28s. Tube LCAs non adjustable.
Old Mar 31, 2013 | 02:45 PM
flyinZ's Avatar
Im running 275/60's on the rear of mine, double adjustable LCA's and I used a BFH mod on the inside, where the bumpstop used to be. I have about a thumb width, front and back.
Old Mar 31, 2013 | 02:53 PM
Mine is about 1/2in front and 3/4in rear.
Radials don't expand like slicks do at speeds.
Old Apr 1, 2013 | 09:17 AM
Stroked96Bowtie's Avatar
Car in my avatar, have 28x10.5 slicks. Slight BFH massage on the inner fender, roll the lip on the fender well, worked like a champ. The rule I follow is if you can stick your thumb between the fender and the tire, you have enough room for slick 'growth'.
Based on the pics, the front and rear gaps look fine to me for those tires. Just need to check the inter fenderwells and lip around the edge.
Old Apr 1, 2013 | 04:27 PM
I BFH the inside of the fenders. Was rubbing now its got about a inch or so all the way around.
Old Apr 2, 2013 | 05:00 PM
First was of the year, street trim is a 4x4 haha.
Old Apr 3, 2013 | 10:21 AM
sweetbmxrider's Avatar
Why do you need 28's?
Old Apr 4, 2013 | 08:36 PM
4.10s with nitrous in a M6.
