Slight hesitation turned bad...
It has been like that for a month but last weekend I put my foot in it a bit and all of a sudden something let go and it does it all the time, like it's running on 7 cylinders. The exhaust smell seems different and you can detect raw gas in it. I thought a wire may have simply come off but they all seem to be on good.
Where should I look first... could this be the opti or should I be doing a leak down test, maybe lost some exhaust valves?
It's not burning any oil and I pulled the drivers valve cover which I suspected was the noiser side and no broken valve springs and clean as a whistle inside! One thing I did try was pulling off one wire at a time while it was running and oddly it seemed somewhat smoother idling when a wire was pulled...
Any HELP?
