REVmax Converters
Old Apr 18, 2013 | 07:28 PM
blackjack325's Avatar
Default REVmax Converters
Been browsing around for a converter and came across these guys.
http://www.revmaxconverters.com/inde...l60e-350.html?
Anyone running one of these on their car? Interested in their 3200 stall.
Old Apr 18, 2013 | 07:53 PM
BOOSTED AFR's Avatar
Reportedly the owner has a history of interesting business practices. Not saying you won't get a converter that works just fine, I just wouldn't bet on it. Custom spec'd converters from Hughes is what I have always run. That or an off the shelf Yank or Vigilante. The 3-5 year warranties and free stall adjustment are a big plus.
Old Apr 18, 2013 | 08:05 PM
NewOrleansLT1's Avatar
Rev Max 4,000 here 1.65 60ft on bald Hoosier drag radials.
Old Apr 18, 2013 | 08:16 PM
Just out of curiosity. When did you buy your converter and how did your car run before the converter?
Old Apr 18, 2013 | 08:33 PM
I bought it 3 1/2 years ago. Before that I had a remanufactured 12" 2800 cutting 1.8 60ft and actually my 1.65 was with a 3500 Rev Max. I sent it in to make it a 4,000 and haven't been back to the track yet
Old Apr 18, 2013 | 08:42 PM
I'm impressed, I've admittedly never owned a REVmax but I did a TON of research on them and didn't like the things I was finding. They appear just exactly like the budget TCI converters that are rebuilt and modified factory converters with tiny lock-up clutches and adapter rings welded to the front of the converters. I think for slightly more money, a guaranteed new converter with a 3 year warranty would be the better choice than a remanufactured converter with a 1 year warranty. Just my .02
Old Apr 18, 2013 | 08:44 PM
porksoda's Avatar
I talked to them before but never ordered. Real stand up guy seemed like to me. I'd say if you're going for a budget converter call up circle D or FTI. They both offer a budget line of converters. I went with FTI for what it's worth.
Old Apr 18, 2013 | 09:10 PM
96capricemgr's Avatar
3800 stall Edge Racing Converter best 60ft of 1.53 at over 4100lbs.
If wanting a "budget" quality converter Edge is as budget as I would go if a few hundred dollars more is doable Yank
Old Apr 18, 2013 | 09:38 PM
wow, pretty surprising actually.
I just dont see myself spending over $500 for a converter. $345 is nice, close to what those Edge converters are running.
I had a Circle D 3000 stall on my 08 sierra, great stall and @$400 it was a bargain! But i think the LT1 stalls from Circle D are around $700?
I use to daily my sierra with the 3k stall, i think id wanna stay around there for my Fbody even if I dont daily drive it. 3200 or so is where id like to be at
Old Apr 18, 2013 | 09:42 PM
buddhaz06's Avatar
I've only heard good about revmax. Good quality converter. I just ordered mine. $435 shipped, good for 500+hp street strip car
Old Apr 18, 2013 | 09:55 PM
Stardust's Avatar
I thought long and hard about my converter choice. I went with Revmax, and they were super great on the phone, we went over my options, and picked a converter best for my application, with a couple upgrades. Just got it installed, will be on the dragstrip next weekend.
Old Apr 18, 2013 | 10:59 PM
Shownomercy's Avatar
Man-Crush Warning
Welded on adapter ring, looks like a cheap 'verter.
How anyone can justify a cheap torque converter amazes me.
Old Apr 18, 2013 | 11:07 PM
In the end of the day, its whatever works at the best price isnt it? Sometimes top dollar stuff doesnt perform like you think it should, and sometimes cheap stuff works really well.
My car wont be a full blown drag car, its mainly a street car which will see some strip use. Rarely.
Im thinking something like the LE2 set up on the top end.
Currently 40 over block on stock top end. long tubes, no cats, 3.73's, cc304 cam, and tune from PCM.
Would really like to hear what stardust thinks of the converter after hes been driving on it
Old Apr 18, 2013 | 11:35 PM
LT11996's Avatar
I plan on daily driving a 3600 Revmax once I get my LT1 running. I researched alot on them and couldnt find any negative reviews. Talked to Mcalus on here since he has the same cam and stall I plan on running and he enjoys it. Everyone with them likes them
Old Apr 19, 2013 | 01:52 AM
za355tx's Avatar
Have a 3200 revmax in my 94 firehawk and so far its been great. Although I'm not pushin crazy hp it seems like a real nice converter. It really woke up this car. Just my personal experience but it has worked great for the 12 months its been in the car. I myself would buy another one.
Old Apr 19, 2013 | 09:23 AM
speed_demon24's Avatar
This is the LT1 section. The cheaper the part the stronger the following it has here, regardless of performance or lack of.
Old Apr 19, 2013 | 09:42 AM
Revmax's Avatar
Ok, let's get some things straight here... Seems as there is a bunch of misinformation being reported...
First of all, all of our components we use are IDENTICAL to the parts used by Yank, Circle D, Vigilante. We all use the 245MM GM core to build our converters off of, PERIOD! So, those of you who spend $700+ on a converter still have as you call it a "cavalier" converter. There is no "NEW" 245MM, 258MM converter housings, there never has been other than when they rolled off GM's line.
We offer two lines for the LT cars, our stage 3 and stage 5. The 3 is perfect for those of you with under 500HP and less than a 100 shot of NOS. For those of you with higher NOS sprays or HP, the stage 5 billet converter is the way to go. We use the EXACT SAME KIT and core components on our stage 5 as do the other converter builders do. FYI the "billet" converters on the market are identical to the non billet converters up to the clutch disc and front cover.
Please do your research and you will find the products we sell are top notch and we back it with the BEST customer service in the industry. There are HUNDREDS of LS1Tech members running our product is there LS cars. Unfortunately, the converter world is one that is filled with mystery and fear mongering. We try to educate our customers and all of you in the community to make it more transparent. Now, if you feel the need to spend hundreds of dollars more on the exact same part, that is your choice, but it will NOT perform any better. If you are ever in Charlotte, we invite you to stop by our facility and check us out!
Old Apr 19, 2013 | 10:01 AM
duh's Avatar
duh
FWIW, I bought my stage 3 3600 stall during the Christmas sale. I'll be getting the trans next week. Since its a stock engine, I can't wait to see how it does on the street and track. When the time comes for a billet converter, I'll probably be going back to Revmax since I work damn hard for my money and I want to get the most out of it, just like everyone else.
Old Apr 19, 2013 | 11:44 AM
Man-Crush Warning
Why is there a price difference if everything is identical then, just paying for the name?
Old Apr 19, 2013 | 11:56 AM
pboxfun's Avatar
I've got a Revmax 3200 stall cutting a 1.6 60ft with mods in my signature. Great converter for driving around in.
