Shoebox, please help me
I ran through the opti and icm electrical test procedures on your site to find that the ground wire on the opti connector (also at the harness end) was reading .96 ohms.. Almost no ground.. So out of curiosity I checked ground to the intake mani, consistently .16 when not running. Though when running I had -1.15 to the block... The frame and body are reading 0ohms. I'm not sure what's going on here but it's something funky and I'm hoping you can help me out
Car runs fine when you first fire it for about 2 minutes. Then gets really choppy and rough. You can kill it and directly after start it and it will again run perfectly normal for a couple minutes before dying down again
I'm thinking this is a ground issue as you said.. I'll have to check ground straps. Where are they all located?
Either way, I was not getting the value that was specified in the procedure on your site and I was hoping you could provide some insight.
So should I chalk this up to being a crap opti?
I've run out of other options and my final step is to order an ALDL and download datamaster.
Get an idea what's going on because this situation where it runs Okay for the first minute has me baffled
I'm hoping datamaster will help point me to an explanation
I have a pretty good idea of what everything means, but I don't see anything that really jumps out at me. Although, I do see left blm at 127 and right at 132 with left o2 at 360-380 and right o2 jumping between 120 and 860
It's running okay on start up in open loop. The right o2 heats up and is "ready" where the left o2 keeps jumping back and forth between "ready" and "not ready" cause it to jump between open and closed loop.
At idle it will finnally settle in open loop. Though it still runs choppy and attpempts closed loop if I snap the throttle.
I don't know enough to say what this really means, could I just have a bad o2 sensor? Is there something more going on?
If you need more info, I've recorded a couple logs
Thank you again
Now It's running okay, and intermittently throwing fits. I can't help but feel like I'm burning some wiring on that left o2
