LT1 stumbling and missing now wont start
Also, if you had six leaking injectors and were flooding it again and again, there's no doubt you have a hefty amount of fuel in your oil and should change it.
So far
1. New fuel pump
2. New tank Due too some pretty nasty looking crap in the old one
Also fuel filters of course
3. New injectors
4. New opti
Not saying that's your problem, but a bunch of oil in the TB is no bueno.
And have someone crank it with the pedal on the floor, leave the injectors in, and spray a little starting fluid directly into the throttle body.
Had a bit of time this morning
Have you checked fuel pressure yet? Wondering if the regulators any good..
A quick tell is to pull the vacuum hose off the fpr/intake and see if there's any fuel in there, or if you can smell fumes.
And when the diaphragm in the regulator wears, it allows fuel to pass into the vacuum line. I would check fuel pressure again. Now that you have new injectors, if it still bleeds down, the regulator could be suspect.
Have you tried the starting fluid again? Figuring out if the car will run when externally fueled will answer a lot of questions.
