LT1 stumbling and missing now wont start
He said he put some octane boost and dry gas in every once and a while and it seemed to keep the problem away. I climbed under and looked and the opti had all kinds of oil/crud everywhere so I bought a summit racing cap and rotor, Taylor 8mm wires and NGK plugs, and a msd coil. changed everything and dumped the octane booster/cleaner in. After getting everything back together car works great.(thought I had it fixed with the crap all over the ignition.) Now the other day at lunch i sat in the car to listen to the radio so after 10-15min I started it to make sure battery wasn't dead and it seemed to have a rough idle. I didn't think much of it so turned it off and at the end of the day we had to go elsewhere so I took it down the street and it was stumbling a little at idle and lowwer rpms. but when I would jump on it it ran ok(down a bit in power tho). Turned it off went for a trip with the boss and came back and took the car home. it ran terribly. After about an hr or two i went to go the auto store to get some grease for the new LCA's/Panhard bar.
and It was hardly able to come up the hill so i turned right around and went back home. By this time it was getting late so i gave up for the night. Next morning and now it wont start at all. It trys to but just wont catch. I haven't got under to check the opti but the plug wires are all okay. and nothing is jumping out at me as a cause. Is there a sensor that goes bad with these engines. or could it be a fuel pump. I can hear the pump prime but thats not saying its pressuring up enough to actually run the car, I am kinda leaning toward the fuel side or electronic sensors since all the ignition parts are new. Any ideas where to start? Thanks Guys!!
WTF I am stumped now????
Anyone with any suggestion on what to try next
Anyone any ideas????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????????????
Also I noticing it really almost seems like its rich there is a lot of moisture coming out of the tailpipe and really dark **** inside the tailpipes. Maybe I am going the wrong way with the fuel and I need to check out the spark side of things.?
--Also had two plugs out and they are a little dark but not terrible. Def not white from a lean condition.
--Spark seems really strong pulling the wire off the plug and grounding it.
--And popped all the injectors off to see if it killed the engine and number 3 didn't seem like it really made the engine bog as bad as the others, But the plug for no.3 doesn't seem like its lean(Stuck injector)
Could it possibly be stuck open maybe causing the pressure to bleed down quickly when I checked that?
Anyone Any Thoughts??!!! This blows
i am really starting to lean toward the opti being the problem. I noticed it actually was spitting unburnt fuel out of the tailpipes. But its wierd b/c the plugs are sparking ( anice bright blue spark when i pull the wire from the plug). I have a new opti sitting down at the auto store so I am heading down now to tear it apart and hopefuuly it will start with the new distributor.
I have another problem now tooo. when i try to crank it its like the battery is dead or the starter is fried but I took both off and took them down to the autostore and they are both fine. would the opti being bad cause this?!?!?!?
Does anyone have any input at all.
