96 Camaro Z28 LT1 fuel injector question
Just need to know what is the largest lb injectors that can be used on a 96 Z28 LT1 engine with mild cam, larger 58mm throttle body and larger ported intake manifold? 26 lbs or higher? Let me know please and also what is the best brand fuel injector?
Thanks very much!
James
Thanks very much!
James
The size of the injector is proportional to your fueling requirements. In this case the need for larger injectors does not exist.
Stock is MORE than enough for what you're doing. There is no power to be had with larger injectors, not to mention anytime you DO change the injectors you need to reprogram the PCM.
Additionally a 58mm throttle body won't be worth any horsepower, nor will the ported intake manifold.
Also I forgot to mention I was running nitrous. Still stock injectors? Also I have programming capabilities for the PCM.
Thanks, but I disagree about the 58mm TB and ported intake that has been on the car for months plus a 4" CAI up to the MAS not affecting HP. More air being sucked into the engine equals more horsepower. I drive this car, I've noticed the difference as I have added these parts. It ain't fiction.
what Ramair means is that your money would have been better spent elsewhere. the gains at this point in your engine build from those mods are very small for the cost... besides you werent even close to maxing out the stock intake and throttle body. there was a study done by someone proving that they arent a choke point till upwards of 400 hp even on 383's and most 350 and 355s wont max them out ever
wet shot or dry shot? if its a wet shot injector size doesnt matter. lt1 dry kits i dont think it matters either... lt1 dry kits raise the pressure to compensate for the fuel needs
9-Second Club
Ramair is dead nuts correct. I have dyno tested about all the bolt-ons you can name, back-to-back on my dyno, with controlled air & engine temps. Usually A-B-A testing, which means changing the parts back to be damn sure about small changes. I'm kinda OCD about this ****. If a given part is capable of flowing all, or near all, the air your engine can pump there will be zero increase in air flow. Only a loss of velocity. 58mm TBs, big or "ported" (butchered) MAFs, ported manifolds on stock heads, all are a total waste of money. Ditto larger injectors. All pissed away money. Won't make you run one bit faster. I'm not the only shop that has tested this stuff.
My buddy built his LT1 and ended up finding some GTP (36 lb) injectors for cheap. He should get his computer back from being tuned tomorrow so then well know how well they work, but always a thought.
Thanks very much!
James
Thanks very much!
James
