Intermediate pipe install
Old Apr 30, 2013 | 09:08 PM
Nucmedkahuna's Avatar
Default Intermediate pipe install
I'm trying to install a new Walker intermediate pipe for my 94 Z28 LT1. I am trying to get it over the axle and suspension, and I have had no luck. I've got the car on jack stands.
Do I have to disconnect anything to make it around the bend? Does the car have to be jacked up really high to make it fit? This is a stock replacement and I'd hate to cut it up to make it work.
Old May 3, 2013 | 12:17 PM
Fazz73jr's Avatar
I'd think you'd have to drop the rear more. Disconnect the rear shocks then the rear should drop more.
Old May 3, 2013 | 12:55 PM
96lt1m6's Avatar
Since you are obviously not using a lift, it will make your day a butt load easier to lift car on stands remove the right rear wheel, disconnect the lower control arm,shock from deafened and pull the spring out. Slide I pipe in place then reassemble.
Old May 6, 2013 | 09:01 AM
Thanks for the advice! I wish somebody could come up with an inexpensive portable lift or something you could rent for quick jobs like this. I just don't have the room or loot to install one.
