Help me with timing!!!!!!
Old May 5, 2013 | 08:33 PM
justins94onthegas's Avatar
Default Help me with timing!!!!!!
First off I would like to say thanks to the many answers I find on this site. Now my issue is I have just put 600 miles on my 355 12.1 1.6rr forged piston stock rods and crank (email tune) the car is solid mount and long tube headers bmr everything with torque arm relocated slp subframes. The problem is knock counts through the roof what do I do I have checked everything and replaced knock sensor. The tune is a bit rich and timing upper 30s
Old May 5, 2013 | 08:43 PM
BOOSTED AFR's Avatar
What kind of gas is in the car?
Have you determined whether the knock is false or real?
Old May 5, 2013 | 08:55 PM
OddballLt1's Avatar
How much are you spraying? Depending on the fuel octane, I may pull a few degrees of timing out of it to help bring the counts down. Whats your AFR at WOT?
Old May 5, 2013 | 08:59 PM
I did a 93/110 50/50 & straight 110 and the car is solid so I feel everything the knock goes crazy when the car is vibrating so I imagine it's false
englundjd's Avatar
according to his list he isnt spraying. your roller rockers could be causing some false knock
Old May 5, 2013 | 09:00 PM
Afr wot is 11.5/11.7
Old May 5, 2013 | 09:03 PM
Should I re adjust the rr I did them with car off but they sound good and I am spraying but not until all motor looks good
Old May 5, 2013 | 09:06 PM
96capricemgr's Avatar
WTF made you think solid mounts and knock sensors go together.
I would start by putting rubber or poly mounts back in it.
Old May 5, 2013 | 09:36 PM
Lol yea I figured solid mounts would be a issue so if one were to inquire a reasonable amount of timing on my setup what would that be
Old May 5, 2013 | 10:08 PM
I would probably program it for a max of say 29degrees, the pcm will add some with rpm so you will see a little more in datamaster but set tunercat for 29
Old May 6, 2013 | 07:26 AM
Ed Wright's Avatar
9-Second Club
Why in the world would anybody not just use stock mounts? Why even poly? Especially solid?
How much retard are you seeing? If you are not seeing any actual retard, ignore the knock counts. Your not going to get rid of them. They are just confusing you.
Some of you guys obsess over things you don't understand. 29 is too low.
Old May 6, 2013 | 09:47 AM
quik95lt1's Avatar
what ed just said..........loose the solid mounts and run stockers........and 29 is too low mid to upper 30's should be fine
Old May 10, 2013 | 07:26 PM
thanks for the replys it helped got on the dyno and car liked 32 and made 453 (on the kit) on mustang dyno and i love the feel of the solid mount
Old May 11, 2013 | 06:30 AM
https://ls1tech.com/forums/17227973-post15.html
different chambers and setups need different timing, that said several of us have found the setup I have o want 29 degrees so that idea should not be dismissed. Plus both guys saying it is wrong are running aftermarket injection which will more accurately report the timing their engine sees.
Pat and I are saying what we use in Tunercat and specifically stating we know it gives it a few more degrees, on top of that who knows how much tolerance stacking there is, maybe there is another couple degrees there. At any rate when tuning with the factory pcm you are going to enter a lower number than what the pcm will see.
Old May 11, 2013 | 06:34 AM
Ed Wright's Avatar
9-Second Club
32 degrees in the factory PCM is 36 degrees at the crank, and is what mine and most others with the correct combustion chambers like.
Btw, iron heads typically use less timing.
Old May 11, 2013 | 06:49 PM
jrwilliams95z28's Avatar
Thats interesting because as I tuned my car i dropped the PCM tune to 28-29* (33 according to datamaster) at the upper RPMS and I have almost eliminated the knock. it only pulls .1-.5* sometimes now. knock counts still go up randomly but if most people are getting 36* I have some hp on the table that my knock sensor isent letting me get.
Old May 11, 2013 | 07:22 PM
Ed Wright's Avatar
9-Second Club
Angry
If it were false knock, pulling it back would not have effected. I doubt you have a knock sensor problem. Sounds like that is all it wants. Could be you have more compression than you think. If you didn't CC and everything you could have more than you think. Or, could be the fuel in your area. For example: Arizona and California has fuel with the same octane as the rest of us. But, their fuel is crap, and cars I tune in that area gets (depending on the combo) two to four degrees less timing that everywhere else. For got about Mexico, less timing down there too. Some of their's is actually just rated at 85 octane.
That E10 ethanol crap is a problem too.
I think you probably have your timing where it belongs.
Good luck.
Old May 11, 2013 | 07:45 PM
Or, could be the fuel in your area. For example: Arizona and California has fuel with the same octane as the rest of us. But, their fuel is crap.
True, it's an ugly fact that all gas is not created equal.
Don't even get me started on Ethanol...if you didn't build it for it. Don't run it.
Old May 12, 2013 | 09:17 AM
Good luck.
yah in my area (ontario) we have 94 octane from the pumps, its the highest we can get here and its all I run but when I used lucas maxboost octane booster my KR dropped a bit.
its still hitting 33* above 5000RPM so I dont think its to far off pace. apparently strong health motors need less timing advance, im not sure if that applies to the LT1 though.
Old May 12, 2013 | 09:34 AM
One shop I talked to put a solid roller 355 on the dyno with aftermarket injection and ran timing from 31-40degrees and it did not knock but did not make any more power either on the higher timing. IMO the old idea that you want timing set just shy of detonation is outdated. Chamber design has come a long ways. If it makes power and goes down the track well at a "low" timing stting then that gives you some safety net shoukld you get poor quality fuel once or something else unexpected.
Really if you think about it in a perfect world spark would be at TDC, sparking before TDC has the expansion beginning to fight the rising piston, would be best if we could avoid that, but the flame takes time to travel and pressure to build which is why we need spark before TDC.
