chipped
Old May 13, 2013 | 09:46 PM
DisturbedTA's Avatar
Default chipped
Wanted to know if anyone has a Pic of where the chipped would be trying to see if my 93 is chipped?
Old May 13, 2013 | 09:52 PM
englundjd's Avatar
all 93's are chipped. the computer itself pulls all the info it needs to run the car off of a factory chip thats in the computer, under an inspection panel
Old May 13, 2013 | 09:58 PM
Yeah so its under the panel mine its blue with a name on it and the computer was remanded in 06
Old May 13, 2013 | 10:08 PM
BOOSTED AFR's Avatar
This ^^ means its been tuned (see the memory adapter in there?)
This ^^ means it has not
Old May 13, 2013 | 10:22 PM
chipped-1368674542990.jpgOh ok this is mine wondering cause my fans kick on like after thirty seconds
Old May 13, 2013 | 10:25 PM
Yours may have been opened up and the actual PROM chip been changed inside the factory MEMCAL. That is the other option for tuning.
See where this guy ^^^^
Is located on this guy ^^^^
Old May 13, 2013 | 10:26 PM
That's what i'm thinking
Old May 13, 2013 | 10:37 PM
duh's Avatar
duh
I would guess yours is by the "Boswell" written in it. I've never seen a chipset with what looks to be someone's name in it.
bought this 4 years ago as a roller came with the Trans and block,the block had a big azz hole in the block! Car came with i&n intake a couple of 1.5 roller top rocker.hooker super comp headers and msd digital 6. I'm thinking he sprayed it lol
Old May 13, 2013 | 10:39 PM
Yeah! My other pcm has just a plain blue chip no name on it
VERY possible
Old May 13, 2013 | 10:41 PM
Shoot I should've looked before I put it back in the car I'll check that our tomorrow, thank you
Old May 13, 2013 | 10:43 PM
Yeah it was on the Dr cylinder think #7 big hole lmao
Old May 13, 2013 | 11:31 PM
I'm admittedly less familiar with OBDI than OBDII. If we're lucky, Ed will stop in here and tell us any other tell tale signs of your car being tuned. I often think that he has forgotten more things about LT1s, tuning, and racing in general than I could ever wish to know, and I'm not all that humble to begin with lol
However, even without that I'd feel completely confident saying your car has been tuned.
Now, that being said. Is the engine similar to the previous set up that the car was tuned for? Or is it time for a new tune?
Old May 14, 2013 | 07:01 AM
shbox's Avatar
Attachment 402566Oh ok this is mine wondering cause my fans kick on like after thirty seconds
Could merely be because of a trouble code.
Old May 14, 2013 | 08:11 AM
Ed Wright's Avatar
9-Second Club
I have seen & redone chips with a label with just a name like that on it, but I don't recall who does that. If the fans come on that soon, on a cold engine, there is something wrong with the car. I can not imagine anyone setting the fan control temps that low in the chip unless they simply mis-typed a number when doing the calibration. Not that hard to do. I would scan it looking for codes or bogus data indicating maybe an ECM issue. Could be a coolant sensor issue, indicatind a higher than actual coolant temp. The ECM wouldn't know the difference, it would just turn the fans on.
Hope this helps.
Old May 14, 2013 | 01:34 PM
Hope this helps.
Yes! I knew he would chime in!
Thanks Ed
Old May 14, 2013 | 03:30 PM
Ok I'll do the paper clip mod now lol thanks allot
Old May 14, 2013 | 03:34 PM
Its probably time for a new tune i'm close to it with bolt ons but idk if the other motor had heads and cam or not but no smoke when I step on it so not over fueling and it looks like the injectors are stock they're in my garage i'm missing the bbk tb I put it on my 95 2 years ago
Old May 14, 2013 | 03:45 PM
JUST code 26 which is emissions which I don't have
