Another One Bits The Dust!!! With Pics
not trying to jack the thread
My Eagle forged crank has issues, but it balanced easily and didn't require any material to be added. Pilot bearing hole is on the loose side and the flywheel centering flange is larger in dia. than stock. Not bitching. I got what I paid for.
hokeplaya05, you strongly questioning the competence of your "builder" yet?
No way in hell I'd run a stock shortblock H/C setup on a cast crank, let alone a stroker or boosted build like some are being told to do.
This. Forged eagle cranks have been 1600+Hp in SBCs, just treat it like any other crank and have it CHECKED before installing. I don't care if its a crazy expensive custom billet job, you still need to check and balance everything before installing.
Far as the Compstar I do have a friend that cracked one at an oil hole and caught it before failure(really good ear), was a 700ish HP smallblock and Callies treated him well when he upgraded to the crank he should have bought the first time around.
