Cat testing
Old May 28, 2013 | 09:23 AM
jrwilliams95z28's Avatar
Default Cat testing
Hey I'm not sure but I've been talking to a buddy of mine at work (he has a ls1 camaro) and he said the ticking I've been hearing when the car is warm and under load (cruise or wot though I can't hear it over the exhaust at wot) could very well be the catalytic converter on its last legs.
Any way to test this theory or just replacement the only way?
It's a single cat 95 with 80,000km, 45000ish miles
Old May 28, 2013 | 10:15 AM
Z28harcor's Avatar
Just ram a rod through the cat and be done with it.
Old May 29, 2013 | 06:38 AM
Lol sounds good haha
Old May 29, 2013 | 08:05 AM
shbox's Avatar
Cats will ratttle...don't know about ticking. Often ticking is an exhaust leak (especially when under a load).
Old May 31, 2013 | 07:10 AM
Would you say for it to tick (as opposed to it being really loud fart sound) that it would have to be fairly close if not right at the head?
Old May 31, 2013 | 08:18 AM
shbox's Avatar
Yes, closer to the head/exhaust manifold is generally where you would hear it.
Old May 31, 2013 | 09:59 PM
ok thanks, that fuels my fire to get off the wallet and buy long tubes lol
Old Jun 1, 2013 | 10:33 AM
FSTFBDY's Avatar
You can test the cat for being clogged with a back pressure gauge. It screws into the o2 sensor bung. take a before and after cat reading.
Like said above a tick is more like an exh. leak. normally at the manifold gasket or collector gaskets.
Old Jun 2, 2013 | 02:09 AM
1993 z28 f1's Avatar
Hey:
Depending on your emissions you could go with one of these if you only have a visual inspection.
http://www.allpurposepipes.com/produ...5827ca6ae2fbfe
That should help with the flow and get rid of the rattle.
Dub
