measured my pushrods, how this look
lifter is solid as well i took it apart and washered it up.
i havent done many and i didnt know if that line looked too thick. it centered nicely though i thought
Don't be surprised to find your new custom pushrods to vary .015" or more, one to the next. LOL
7/16-20 thread stud, one turn equals .050 so a half turn preload will sink the lifter plunger .025, would the optimum pushrod length then be 'best pattern length + desired lifter preload (half turn .025)?
Or is this just splitting hairs?
use a stock 7.200 to get a base pattern mark on valve tip. Then use a caliper to set the adjustable PR check tool .250" +/- more or less depending which way you need to go. "Generally" with decked heads & block you need slightly shorter. Many aftermarket PR come in lengths with incriments of .250 in length
If the pattern is closer to intake, get longer PR. if towards exhaust side of head, get shorter. Yeah you can order custom PR at any length say a 7.087 as example....but the diff between that and a 7.100" is nothing...unless you are building a $50k NASCAR motor so just order a 7.100 off the shelf.
More important, IMHO, is get a thicker .080 wall PR to reduce PR flex. Hardened PR are required if using guideplates for NSA RR
I hate those adj p-rods. I have one and tried to use it once and realized thats for a an engine on the stand, not one in the car. Just bought both a Manley and ProForm p-rod checker for like 10 bucks and found my p-rod length in seconds - not hours.
http://www.summitracing.com/parts/pr...FRGCfgodsVkAgQ
And like Ed said my new p-rods from Trick Flow came like 0.005" different than the number etched on the p-rod but still worked great.
Let the NASCAR kids play with the adj p-rod checker,
cardo0
