Zero oil pressure out of nowhere *PICS*
#63
Got her all back together and it has oil pressure again.
Here's an idle vid. Not sure if it will work though... https://www.facebook.com/photo.php?v=10151446011062413
#65
Good Job! Keep an eye on the magnetic drain plug for filings or slivers, IMO black paste residue is normal. Don't over check it either, you'll miss the forest for the trees.
#67
Suppose it's possible. I moved the P/R up and down till I could no more, then did a 1/2 turn. I did not soak them in oil, but I did soak them in mineral spirits. Maybe I could have a vacuum leak somewhere too. I am also running open Y pipe right now cause I was in the process of getting new exhaust when it broke, so that always make it feel doggy.
