When will it stop, motor locked up
Old 06-26-2013, 11:45 AM
96Formula6spd's Avatar
Originally Posted by SS RRR
Teflon doesn't give out that easily unless it's installed wrong or something else is amiss. If this isn't top end related you need to take the block to another shop and have them check out the block to see if it's true. If it did hydrolock then most likely you have a rod or two that is no longer straight.
When I pulled the seal it was torn up on the inside edge. I have never liked teflon seals. Yeah if I decide to tear the thing down years from now I bet a few rods are bent along with some other items. Pretty much I would pull the good bits and scrap the rest. However I am not in the mood to pull the motor, or even look at it anymore.
Old 06-26-2013, 12:16 PM
Village Troll
SS RRR's Avatar
I sort of feel your pain. My **** is on jackstands, only needs valvesprings replaced, hasn't been run for months, yet I can't find the motivation to take the couple of hours to get it done. I think if something like that would happen to my heap I would set it on fire.
Quick Reply: When will it stop, motor locked up
