Evap System Problem/Question
Old Jun 10, 2013 | 09:54 PM
DAVE00's Avatar
Default Evap System Problem/Question
Guys,
After a lenghty cruise a couple weeks ago with temps in the mid 90's I unscrewed the gas cap to fill up and the pressure was overwhelming. It releaved pressure for atleast 3-4 seconds and was pretty forceful flow of fumes coming out of the filler neck. I've checked the lines to and from the purge solenoid to the char canister and everything is clear and flows freely. The lines are good and there is no vacuum leaks, but can I test the purge solenoid somehow to make sure it's functioning properly? Also, I'm getting no codes.
Lastly, is there anywhere else I could check as the tank should not hold that much pressure? Thanks and any advise is appreciated.
Old Jun 11, 2013 | 02:53 PM
DAVE00's Avatar
Anyone???
Old Jun 11, 2013 | 09:51 PM
wrd1972's Avatar
Since I have forgiven you for chewing my *** out for selling a use throw out bearing on the board several years ago, I will now gladly respond.
If you are confident the line from the canister is clear (which I doubt), the issue must be the solenoid not opening like it should. If you take the solenoid off, you should not be able to blow air through it. Once you apply 12V DC to it, you should be able to blow air for it. Most of the time, there is charcoal from the canister clogging the line from the canister.
Old Jun 12, 2013 | 09:22 AM
DAVE00's Avatar
Thanks man, bygones be bygones. As to the line, I'm positive it's clear as I can get a nice buzz all day long breathing fumes through it with no restrictions. I pulled the line off and applied vacuum and it flows freely. I'll check the solenoid as that could be the problem, just not sure. Also, could the vent valve between the canister and the tank be the culprit? And if so how can I check that one (not the white secondary vent valve)?
Old Jun 13, 2013 | 06:47 AM
DAVE00's Avatar
Anyone else?
Old Jun 15, 2013 | 10:18 PM
DAVE00's Avatar
Okay, got an update. Pulled the Charcoal canister and all looked good, no charcoal and lines are clear all the way from the tank to the purge solenoid in the engine bay. The solenoid works just fine as I put 12v to it and it opens/closes just fine. Also, the evap pressure control valve connected to the charcoal canister works just fine and flows. I replaced all the hoses as they were pretty dry rotted, but I'm still unsure why the tank is pressurizing so much? Could the low vacuum from my cam cause the EVAP system to not work very well? As that's the only thing I can think of?
Old Jun 16, 2013 | 07:38 PM
95blackm6's Avatar
Im not sure of your exact problem, but I know that my car builds a lot of pressure when its hot out and has anything below a full tank... I have replaced the charcoal canister with an AC Delco unit, blew out all the lines, tested/cleared out the EVAP solenoid and have checked all the lines at the sending unit... I think that maybe the valve at the tank/canister might be bad?? Not sure yet.
Old Jun 16, 2013 | 09:39 PM
DAVE00's Avatar
I know what you mean as I'm really wondering what is going on here or if I'm just being paranoid. I did the same and all my evap components function normally and are clear. Also, the line coming from the tank is clear as when I disconnected the evap valve at the canister I got a nice steady flow of low pressure fumes. I'm wondering if I don't have enough vacuum to properly actuate the valve to allow for proper evap flow. Also, is this just a normal thing and I need to learn to live with it? But all during the 18 years I've owned this car I don't recall the pressure in the tank being this much, so I'm stumped.
Old Jul 2, 2013 | 11:17 AM
ukcatfan's Avatar
I have a similar problem on our 1997 Trans Am convertible. We have tested all the lines, replaced the canister, the evap solenoid and the evap switch. Been to two different shops, both said it was fixed, in both cases the CEL came back on within two days. We are at our wits end trying to figure out why we still get the same P0440 error code. We've also replaced the gas cap 2 times.
Old Jul 2, 2013 | 11:28 AM
flame's Avatar
The cap used on these cars is non vented. There is a vent that hangs down under the car left side back seat area maybe it's plugged
Old Jul 22, 2013 | 06:23 PM
thingthatgoes's Avatar
I just posted on an old thread about this today....
I have the same problem, except worse. To the point where I can't fill with gas, unless I relieve the pressure by sticking a tube down into the gas tank. (It feels like I have to push back against a check valve). I haven't gotten as far as anyone else here to diagnose the problem, but the only last thing I can think of to check is: The fuel tank pressure sensor? Maybe the ECM isn't seeing pressure, so it doesn't send a signal to open the purge valve.
That's all I can think of.
The purge valve gets a fast pulse from the ECM to operate, so I'm not sure that responding to a steady 12v is enough to know it works right. And I don't have the equipment to test the signal going into the purge solenoid. And I sure as hell don't know if I'm ready to get to the pressure sensor in the gas tank.
