Dent in Oil Pan??
Now its time to tear it apart, my main question is where do i jack?! i dont have a engine hoist so i need to know where to jack and not hurt anything. And also tips on lowering the k member, should i get a jack under it, then loosen the bolts then lower it down?
And then when it all goes back together, how tight does everything need to be?? (TQ Spec)
if you need to ask torq specs for replacing stock bolts like that just buy a haynes. only thing they are really good for
it runs between pan and gasket on the ends of the pan
put gasket on bottom of block (IIRC felpro includes 4 blue plastic studs to hold it up then you put pan on. use a few pan bolts to hold it in place, remove plastic studs)
