What shaft mount rockers to get?
My rockers are pretty far off on the valve tips and I really don't have the time or people to help me install isky's. so I'm asking what is the best shaft mount rockers to get and where can I get them? Or you guys think I should tough it out and really try to bribe a friend into helping me? I just really wanna drive my car. Thanks in advance.
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
I am spinning my engine to 7200rpm using stud mount rockers. As stated, no need for shaft mounts. If you have problems with alignment you can either go with Isky adjustable guide plates. I know RamAir uses a different set and has no alignment issues.
as said above shaft mounts are not needed in that setup.....run a good set of nsa rockers and you will be fine like the cranes mentioned above, Harland sharp, comp, etc.... measure for correct pushrod length and you will be fine.......if you are hell bent on shaft rockers the jesel sportsmans are a good price and a great rocker I run them on mine
