Searching for LT1 4 - bolt main block!
Old Jul 2, 2013 | 08:13 AM
SwampWS6's Avatar
Default Searching for LT1 4 - bolt main block!
Is their anyone in this forum selling or knows anyone who is selling a LT1 4 bolt main block? Just trying to save money on getting the caps splayed even though its potentially stronger than factory 4 bolt main. Let me know, very interested.
Old Jul 2, 2013 | 09:23 AM
ahritchie's Avatar
Shipping engines is not cheap...unless some local junkyard has a LT1 Corvette around, you should probably look into getting your 2 bolt LT1 splayed, or do a real upgrade to a LS It has 6 bolt mains, which by my calcuations, makes it 3X better than your 2 bolt LT1
Old Jul 2, 2013 | 03:03 PM
Quazz's Avatar
I splayed mine. Money well spent.
Old Jul 2, 2013 | 05:02 PM
BIGCAT7274's Avatar
pm dawdaw on ltx tech. he mentioned he had one a while back he was wanting to get rid of.
Old Jul 2, 2013 | 08:15 PM
BoostedDSM's Avatar
I just sold my 4 bolt main motor too.
gjohnsonws6's Avatar
I still have one...
Old Jul 2, 2013 | 09:18 PM
96capricemgr's Avatar
By the time 4-bolt really matters vs. studding the 2-bolt you should be looking at aftermarket caps anyway. The machining plus having paid a premium for the block means no savings.
The guy with the fastest NA Impala putting 500ish rwhp down runs studded 2-bolt, but everyone here building a mediocre stroker wants to spend the cash on 4-bolts and "save" money on the topend. If you have the cash to spend great, if it is going to cause you to cheap out somewhere important like topend maybe reconsider.
Old Jul 3, 2013 | 02:39 PM
KW Baraka's Avatar
Originally Posted by 96capricemgr
..........but everyone here building a mediocre stroker wants to spend the cash on 4-bolts and "save" money on the topend.............if it is going to cause you to cheap out somewhere important like topend maybe reconsider.
I don't always agree with Dwayne......but I gotta go with him on this one.
Either go with a two bolt......or splay your block. The GM OEM 2-bolt is a pretty damn strong block.....and the OEM 4-bolt is weaker than what a good machinist would do for ya.
KW
Old Jul 3, 2013 | 09:40 PM
Boosted Firehawk's Avatar
Pm me. I'm in Chicago and have a lt4 motor bored 60 over 200 bucks. Just the block no crank or rotating assembly
Old Jul 3, 2013 | 10:12 PM
IMO a block bored .060 over is not going to have strong enough bores to even consider needing 4-bolt.
Old Jul 4, 2013 | 05:51 AM
joelster's Avatar
What was I thinking? I should have gone with a 2-bolt main!
Old Jul 4, 2013 | 07:11 AM
BIGCAT7274's Avatar
Old Jul 4, 2013 | 01:27 PM
SoxXpupPeT's Avatar
I picked one up here on the forums. complete shortblock shipped from Va to NY for $400 just gotta find one. I am going for a stock 4 bolt main because if you look at the webbing its stronger in the stock location then if it were to be splayed. just my .02 tho.
Old Jul 4, 2013 | 01:30 PM
KW Baraka's Avatar
And then......we get back to normal......where I often don't agree with Dwayne.
My issue with a .060" overbore ain't the 4-bolt mains, it's the .060" boring.
This is generally considered the max you can bore a LTx engine without cutting into the water jackets. The engine is still servicable, just that you may not have the wiggle room to cut the bores in the future.
The fact that the engine already has 4-bolt mains is a small bonus over a two-bolt engine.....NOTHING at all wrong with that !!!
KW
Old Jul 4, 2013 | 06:20 PM
The splayed vs. straight argument gets beaten to death but honestly if making enough power both are upgrades over 2-bolt so it seems to be splitting hairs.
The LT1 4-bolt blocks are the same castings as the 2-bolt.
Guys with stout 383 setups can see bore movement in NA LT1s at a .030 overbore and given enough time crack the deck or a bolthole to a bore.
If I were going to even consider a .060 over bore I would want to see the receipt for the sonic test. There are those who use a.060 overbore but anyone with a clue would do so cautiously and sonic test the block first.
Far as further cleanup on future rebuild how about just getting the bore and hone right for whatever new pistons you order?
Old Jul 5, 2013 | 07:44 AM
SwampWS6's Avatar
My goal for this first block is to get between 420-440 rwhp. My machinest said that a 2 bolt would be totally fine for that goal. But if I were trying to do a big shot of nitrous or turbocharging (which is my main goal. 88mm) it he would prefer me to either get a 4 bolt or get the caps splayed. With the first engine I am not trying to go ridiculous. But the 396 is what I have the serious plans for. What do you guys think?
Old Jul 5, 2013 | 08:14 AM
Ed Wright's Avatar
9-Second Club
LOL!!!
That's .015" wall thickness. Do people really think sonic testing can get it that close? Not that I have seen after cutting a couple of blocks apart.
Btw, LT1 blocks are not "really strong". They are typical late model GM thin wall castings, of shity cast iron. If you ever start to make any power (not talking 400) you are going to have a hard time keeping your cylinders straight. Rings don't seal in cylinder walls that move around. Fill the water jackets, and when you put it back in the hone at the end of the season, and first pass with the hone you will see where the grout stops. That costs HP.
Old Jul 5, 2013 | 09:06 AM
fex77k's Avatar
I sonic checked my 396 when it was apart, very little meat in them, it's a factory 4bolt that I had to sleeve. It all comes down to how long you want it to last.
Old Jul 5, 2013 | 10:35 AM
97Z28SS's Avatar
Ever consider putting a main girdle on your studded 2 bolt, that will strengthen the bottom end also?
Old Jul 5, 2013 | 04:04 PM
I kn ow girdles are popular on Furd 302s. If it were a good way to strengthen a SBC I think we would see more of them and from some decent companies. I think the particular weaknesses in each block design demand different solutions and just because a girdle is a good addition to one engines doesn't mean it is the answer for another.
