new parts and now it wont start.
I would still triple check your wires and pull the opti to at least loctite it, then carefully reinstall and before you put EVERYTHING back together, hang the waterpump by 2 bolts to plug in the water temp sensor and try to fire it quick. If that doesn't work try the old opti again.,
Thanks to everyones help. After taking it apart again double checking the distributor and attempting to see if it would fire (without putting much of it back together) still nothing. So I figured I check the wires again for like the 5th time. I started on the right bank , which I only checked once because I was 100% sure I had them right, and surprise I had two of them crosed. Tryed it again and half a crank and it fired. After all that work it could have been fixed in 10 min. Hopefully now after a full assmembly it will run like it should once again.
Thanks again to everyones advice,
Luke
Luke
