lt1 restoration final steps have a bcm question
Old Jul 17, 2013 | 03:47 PM
powercrazy's Avatar
Default lt1 restoration final steps have a bcm question
96 trans am 24x conversion installed a bcm out of a 96 z28 everything works but the car doesn't start. I know that the car and the bcm have to be synced up for the car to run. My ignition key doesn't have a resistor chip in it. So what needs to be done to have everything work at should. Thank you for the help!!!
Attached Thumbnails lt1 restoration final steps have a bcm question-img_0093.jpg   lt1 restoration final steps have a bcm question-img_0091.jpg
Old Jul 17, 2013 | 03:50 PM
draggin97s10's Avatar
Solder in a resistor in the vats wire(yellow i believe) that runs down the column. That's the easy fix
Old Jul 17, 2013 | 04:03 PM
powercrazy's Avatar
there is no way of know what the resistance should be without the chip in the key correct?
Old Jul 17, 2013 | 04:08 PM
I'm sure there is, but I cannot tell you how to figure that out. There is a range of them. I think we just bought 4 or 5 and Swapped them until one worked. Someone could tell you the range of resistors that worked or you could find it somewhere.
Sorry i'm not being much help.
On a buddies car we tested the key and did it that way.
Old Jul 17, 2013 | 05:55 PM
ltxMonte's Avatar
The resistance for the vats are: 402, 523, 681, 887, 1130, 1470, 1870, 2370, 3010, 3740, 4750, 6040, 7500, 9530 and 11800. Since you don't have the chip for the key, you will unfortunately have to build all 15 and try them. A bulk pack for radio shack runs like $15 and has all the values to make them many times over.
Old Jul 17, 2013 | 06:01 PM
powercrazy's Avatar
ok thank you very much once I find the correct value the car will start with the z28 bcm there is no other way such as with a tech 2
Old Jul 17, 2013 | 09:53 PM
SoxXpupPeT's Avatar
Or just tune it out of the ecu. OP your car looks SICK!
Old Jul 18, 2013 | 12:59 AM
BizZzatch350's Avatar
Moderator
My 93 didn't have a BCM so I never had this issue, but clean Trans Am
Old Jul 18, 2013 | 08:48 AM
xBrandonx's Avatar
Here's a pre-made bypass, http://www.ebay.com/itm/Vehicle-Anti-Theft-System-VATS-Bypass-Keycode-12-/281122283221?pt=Motors_Car_Truck_Parts_Accessories&hash=item4174319ed5&vxp=mtr
Old Jul 18, 2013 | 09:18 AM
There you go! That is what I did. and then
Old Jul 18, 2013 | 04:31 PM
powercrazy's Avatar
I like that piece that is on eBay but my key doesn't have a chip in it and the bcm is out of another car. So I need to find out what resistance that bcm is looking to see. So I guess the try one resistor at a time unless there is a way to test what that bcm is looking for. Appreciate the advice everyone.
Old Jul 19, 2013 | 09:42 AM
nitrous2fast's Avatar
If you had a potentiometer and a multimeter you could find out decently quick. Don't know if it would be faster or not.
Old Jul 21, 2013 | 04:34 PM
ltxMonte's Avatar
You can tune the vats out of the pcm, but not the bcm, which kills the starter. I don't know that the other way would be any faster...
